The Best way to root Droid x running Android 2.3.3, system 4.5.605
This is a discussion on The Best way to root Droid x running Android 2.3.3, system 4.5.605 within the Droid X Hacks forums, part of the Droid X Development category; I am a newbie with Droid X and have seen some posts touting Z4Root and then other posts read that Z4root will not work on ...
Thread: The Best way to root Droid x running Android 2.3.3, system 4.5.605
    Points: 56, Level: 1
    Level completed: 12%, Points required for next Level: 44
    lj117y's Avatar
    49449
    Oct 2011
    I am a newbie with Droid X and have seen some posts touting Z4Root and then other posts read that Z4root will not work on this system version. I have also seen some other posts about toggling the radio button can work without rooting. Can anyone give me a clear approach?
    Points: 3,573, Level: 37
    Level completed: 49%, Points required for next Level: 77
    Overall activity: 0.6%
    ajp's Avatar
    444
    SD
    223
    http://www.DroidXForums.com/forum/sh...d.php?p=421453
    GB.602! ROOT! Start here! Links to all
    This will work with 605 too. They're essentially the same. What you'll be using is the d3 (droid 3) one click method.
    Edit: and you're right about z4root - that was for froyo (2.2) - what the DroidX shipped with initially. We're up to gingerbread (2.3) now, which is what 602/605 are and what you've got. Good luck. Let us know if you have any issues!
    MIUI 1.12.30
    proud X owner since launch day
    Points: 975, Level: 16
    Level completed: 75%, Points required for next Level: 25
    Overall activity: 0.0%
    Jaeson23's Avatar
    1457
    SL, UT
    11
    I just did this one last Saturday and found it to be the easiest and most straight forward.
    Pete's Motorola Root ToolsL...
    DX Ice Cream Sandwich OC'd 1187 Mhz
  1. Just got a DROID X2 running 2.3.3 and wanting to root.
    By mpierce in forum Droid X2 Hacks
    Last Post: 12-11-2012, 12:04 PM
  2. Droid X running 2.3.3 how can I root???
    By ikeman32 in forum Droid X Rooted Issues
    Last Post: 08-04-2011, 09:07 AM
  3. Replies: 1
    Last Post: 12-20-2010, 04:43 AM
  4. Replies: 6
    Last Post: 12-14-2010, 08:28 PM
  5. [Video] DROID X running Android 2.2
    By wuyanks in forum Droid X General Discussion
    Last Post: 08-03-2010, 03:17 AM
Root droid x
best root for droid x
best way to root droid x
best way to root droid x 2.3.3
droid x android gb 2.3.3root
how to root droid x 2.3.3 4.5.605
root droid x 2.3.3
root droid x 2.3.3 605
z4root for 2.3.3
