DX always goes into CW then normal after rebooting from there.
This is a discussion on DX always goes into CW then normal after rebooting from there. within the Droid X Hacks forums, part of the Droid X Development category; Is there a setting that tells my phone to always boot to clockwork first? I don't remember changing anything but it always has since going ...
Thread: DX always goes into CW then normal after rebooting from there.
    Points: 732, Level: 14
    Level completed: 32%, Points required for next Level: 68
    COVZ06's Avatar
    45878
    Aug 2011
    25
    Is there a setting that tells my phone to always boot to clockwork first? I don't remember changing anything but it always has since going to gingercomb
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    I had that problem a long time ago. Ultimately, it took a complete removal of all vestiges of bootstrapper to stop it from happening, when I re-installed bootstrapper, the problem did not come back, so, you can try that
    to remove Bootstrap
    with any root enabled explorer:
    1.backup your bootstrapper apk to the sd card
    2.uninstall the bootstrap app
    3. Use a file explorer that allow root r/w access to the system folder. (ES file explorer, root explorer, etc)
    4. Open the explorer of your choice, navigate to the folder /system/bin
    5.Find the file named hijack, long press on it, select delete,
    6.Find the file named logwrapper, long press on it, select delete,
    7. Find the file named logwrapper.bin, long press on it, select rename, and rename it to logwrapper
    8. reboot
    COVZ06's Avatar
    45878
    Aug 2011
    25
    Thanks, I will try this when I get home. Seems easy enough.
    COVZ06's Avatar
    45878
    Aug 2011
    25
    Evidently I have no clue what the BS apk is called or where it is located.
  1. Normal ROM
    By ozzie in forum Droid X Help
    Last Post: 08-21-2011, 09:44 PM
  2. Is this normal?
    By skyshadow in forum Droid X2 General Discussion
    Last Post: 07-22-2011, 04:00 PM
  3. Normal rom??
    By richgangsta41 in forum ApeX
    Last Post: 07-14-2011, 02:45 PM
  4. Not thr normal battery app question
    By Skins45 in forum Droid X Help
    Last Post: 03-01-2011, 08:42 PM
boot droid x clockwork
droid x always boots into clockwork
droid x goes into clockwork after each reboot
droix always boots to clockwork
