Darkslide_X questions (just installed..my first ROM!)
This is a discussion on Darkslide_X questions (just installed..my first ROM!) within the Droid X Hacks forums, part of the Droid X Development category; I finally took the plunge and went from the OTA .602 GB to Darkslide_X! I first sbf'd to 2.3.340, rooted, did the 2 part update ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Darkslide_X questions (just installed..my first ROM!)
    Points: 266, Level: 5
    Level completed: 32%, Points required for next Level: 34
    250 Experience Points31 days registered7 days registered100 Experience Points
    robc311's Avatar
    46134
    Aug 2011
    Florida
    21
    I finally took the plunge and went from the OTA .602 GB to Darkslide_X! I first sbf'd to 2.3.340, rooted, did the 2 part update to rooted GB .596, then the Darkslide_X and patch. It basically took me all day to figure it all out but it's done and working fine (as far as I can tell). I chose Darkslide_X because most people seem to think it's less buggy and easier to use than some other ROMs. This is the first time I have ever modified my DX...had never rooted or Rom'd so I didn't want to get all crazy. Now I'm wondering what next...I've read a little about overclocking, tethering, themes, removing data throttling (is this even necessary?), etc.
    So, what are your suggestions? I'd like to hear what you all suggest for must-have root apps and what I should do next, if anything. I know other ROMS like Liberty have toolboxes...but I don't think Darkslide_X does...does that really matter? Thanks for all your tips...this site has been really helpful!
    Themer
    Points: 4,766, Level: 44
    Level completed: 8%, Points required for next Level: 184
    nemosfate's Avatar
    27305
    cincinnati
    1,080
    20 times
    Get titanium backup to backup apps and app data..get a file explorer for root like Root Explorer or ES File Explorer.. If you want to do screenshot get Shootme or Drocap , I've had best luck with shootme....As far as themes I know theres bluebread that will work and Wulf's blue, green, orange, red, and dark river themes for dsx ....
    [Theme] Darkslide X colored River themes, What color will your DSX swim in?
    root, roms and themes oh my!
    X Pursuant Achievements:
    fernbch's Avatar
    45190
    Aug 2011
    Fernandina Beach, Fl
    642
    8 times
    No, DarkSlide does not have the toolbox and it's a deal breaker for some. I have DSX and have installed Wulf's blueriver theme and crt mod (they are cool). I also have Root Explorer, Titanium Backup Pro, Jrummy's Android Overclock, Nema's battery calibration (more later), meta and ninjamorph, and a couple.other apps.
    There are two things you should do. Get a battery calibration app such as nema's. This gives you the easy way to delete the batterystats.bin file. It's a good idea after flashing as each rom may report battery stats differently.
    If you get Titanium Backup, also use it to clean up your davlik cache. It will scan it and delete any unneeded file in it.
    You should also use D2 bootstrap and create a nandroid backup of your setup, it will be a big help if you ever need a restore.
    One other thing. Go to the market, if you haven't already, and download "spare parts+". The version of sp+ that comes with dsx will force close if you try to view batt stats witj it. This is a GB rom issue, not a spare parts issue. After installing it you won't get the fc anymore.
    After installing TiBu, you can uninstall the spare parts that came with dsx as it is no longer required.
    My Droid Thrives on the DarkSlide!!!
    Sent from the pc, but the Droid still lives...........
    robc311's Avatar
    46134
    Aug 2011
    Florida
    21
    Thanks...I am off to the market! Any advice on a good tethering app or are they all basically the same? Any idea if the phone will charge while tethering via usb cable? Thanks again to both of you for the quick replies!
    fernbch's Avatar
    45190
    Aug 2011
    642
    8 times
    There are a couple tethering apps, but I don't tether so I am "uneducated" about them. I do know that TBH has one abd also wugfresh?? If I spelled it right.
    robc311's Avatar
    46134
    Aug 2011
    Florida
    21
    Ok, a couple of questions...what's the difference between the Titanium backup and Nandroid backup? I assume I need both but I don't know why. Also, I have Astro file manager...is Root Explorer a replacement for that? Lastly, what is Spare Parts for? Thanks again!
    Points: 2,431, Level: 29
    Level completed: 88%, Points required for next Level: 19
    justifi's Avatar
    31869
    Ny, Ny
    157
    The actual titanium backup is called a nandroid.
    Points: 6,372, Level: 52
    Level completed: 11%, Points required for next Level: 178
    savagerun's Avatar
    41501
    2,204
    54 times
    Open Garden wifi tethering has never failed me.
    Points: 3,238, Level: 35
    Level completed: 26%, Points required for next Level: 112
    havensed's Avatar
    18121
    Portsmouth, Virginia
    297
    Nandroid is when you make a backup from Dx or d2 bootstrap, ie bootstrap recovery mode. Ti backup is just that to.
    Apex 2.0 RC2, at my speed, blurless is amazing, very blacked out with super green accent.
    Rooted and Running Apex 2.0 Rc2 loving it....
    Themer
    nemosfate's Avatar
    27305
    cincinnati
    1,080
    20 times
    Quote Originally Posted by justifi View Post
    What? Titanium backup is an app from the market that backs up apps and app data and also you can freeze any app you don't want on there
    Nandroid is a backup you create in ClockworkMod, it backs up the rom the exact way it is setup when you make the nandroid,
  1. Replies: 4
    Last Post: 11-04-2011, 10:49 PM
  2. installed first ROM
    By Android2010 in forum Droid X ROMs
    Last Post: 05-02-2011, 12:52 PM
  3. First ROM installed - Questions and an issue
    By spex921 in forum Hacking Help
    Last Post: 03-27-2011, 11:24 AM
  4. Apps Installed Fine - Questions After The Install Now
    By User0101 in forum Droid X Help
    Last Post: 08-05-2010, 10:00 AM
  5. Best Buy Questions and Answers along with other Verizon Questions
    By taypotts in forum Droid X General Discussion
    Last Post: 07-14-2010, 03:29 PM
droid x ninjamorph .602
open garden wifi tether verizon
