HELP!!! cant get to .596 from .340
This is a discussion on HELP!!! cant get to .596 from .340 within the Droid X Hacks forums, part of the Droid X Development category; First of all I avoid forums like the plague because i usually find a solution, even if it takes me about a week to find ...
Results 1 to 9 of 9
Thread: HELP!!! cant get to .596 from .340
    Tagger Second Class
    gazurbeem's Avatar
    42896
    Jul 2011
    Angry HELP!!! cant get to .596 from .340
    First of all I avoid forums like the plague because i usually find a solution, even if it takes me about a week to find the answer. this has taken me too much time.
    full description (cut to the chase)
    bricked my first droid X and was sent a new one (might be important)
    I have all the drivers and sbf files and have sbf'd my phone nearly 30 times now (no exaggeration) from .577 to .320 to .340
    all the guides say to do this that i have seen
    tried to do the .596 2 part method using 'droid 2 bootstrap v 1.0.0.5'
    i always get an error on part one (status 7) in gb and froyo for either 'asset failed' or 'bad zip' or 'error in xxxxx.zip'
    part 2 installs fine, but i need part 1 first
    then tried to do the .588 3 part method using the same stuff
    part 1 fails in some way and i get 'status 7'
    I made sure script asserts and signature ver. is disabled
    I honestly dont remember if i used 'fix permissions' in rom manager (i have premium) but i think i have a few times (ill try again with it to make sure)
    I am at a loss and really want my droid x to have GB 4.5.596 to install CM7 (my radio and baseband werent the right version in .577)
    any help or suggestions? i can do nearly anything under the sun with my X without going through the web to find what different acronyms and such mean or how to do what is suggested properly.
    Thank you in advance
    Points: 1,770, Level: 24
    Level completed: 70%, Points required for next Level: 30
    Cowboy24's Avatar
    38071
    Texas
    51
    Have you tried wiping dalvik, cache and factory reset after sbf/before install?
    What sbf method are you using?
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    You can install cm7 from froyo.
    But if you want to run gingerbread, you just need to install the 2 zips after a fresh sbf. That fixes the errors 100% of the time. So just sbf to froyo, root, install d2 bootstrap, flash the files. If you're still getting the error, you're doing something wrong. Also, make sure you're using the full sbf, not the system only.
    Points: 952, Level: 16
    Overall activity: 1.0%
    harDnox's Avatar
    37322
    67
    Maybe your md5 are not matching up? ;/
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    Like Snow said, SBF>root>flash the two part zip. Status 7 is indicative of missing/frozen bloat, flashing after a fresh SBF will solve the problem. That is, if you want 596 because you can flash it from either firmware.
    Tagger Second Class
    gazurbeem's Avatar
    42896
    Jul 2011
    I'll have to try wiping dalvik. I did do the flashing after a clean sbf (first 320 then the SysOnly 340) rooted with z4 installed D2bootstrap and flashed.
    SBF method: RSD lite 5.0 windows 7
    RS Team Leader
    Points: 26,927, Level: 97
    Level completed: 58%, Points required for next Level: 423
    Overall activity: 99.9%
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    Quote Originally Posted by gazurbeem View Post
    Get the full .340 SBF file.
    on the move..
    1KDS's Avatar
    3981
    6,904
    573 times
    There's your problem. Use the full 2.3.340 file only.
    Edit: ninja'd, nice pop
    Tagger Second Class
    gazurbeem's Avatar
    42896
    Jul 2011
    just found the solution for CM7 full walkthrough for those that happen across this and need it http://tweakmydevice.com/wp-content/...to-Droid-X.pdf Thank you for all the help again :-)
.340 to.596
.596 to .340 fail radio
596 to 340
bootstrap v.1.0.0.5 droid 2
droid 2 bootstrap apk v.1.0.0.5
droid x .340 to .596
droid2bootstrap.apk 1.0.0.5
find at 340
find at 340.
one click. 340 to .596
