SBF Flash from OSX / iMac / Macintosh
This is a discussion on SBF Flash from OSX / iMac / Macintosh within the Droid X Hacks forums, part of the Droid X Development category; 4/2/11 WARNING WARNING.. THE MAC VERSION ISN'T VERIFIED TO BE SAFE YET. Proceed ONLY at your own risk. From scanning the SBF thread I didn't ...
Results 1 to 8 of 8
Thread: SBF Flash from OSX / iMac / Macintosh
    Points: 7,190, Level: 56
    Level completed: 20%, Points required for next Level: 160
    Overall activity: 1.2%
    bsbabcock's Avatar
    16420
    1,342
    96 times
    From scanning the SBF thread I didn't find specifics on it but maybe OSX users might appreciate it, and I'd love to read if any have done this. I'm told in Linux its a breeze so maybe this OSX version may also be easy. Looks like it. Fill us in if you've used this flash method.
    Flashing sbf from directly within OSX on a Mac Post#69 in the mdw forum thread:
    (Not yet) Root with GB 2.3.3 work togther
    Quote Originally Posted by Kevcube View Post
    Yes, search sbf_flash. Provided you have knowledge in using a terminal, it should be easy. If not..
    1. Put phone into bootloader mode, NOT usb debugging, and connect tolike computer.
    2. Download the sbf_flash binary.
    3. Open a terminal, /Applications/Utilities or something like that.
    4. Use finder to put the sbf_flash file you downloaded and your sbf in the same folder, and cd to that folder in terminal.
    5. Type exactly this, "chmod +x sbf_flash" [PRESS ENTER] "./sbf_flash" then type the first few letters of your sbf, case sensitive, and press tab.
    6. Your comp will do the rest!
    Sent from my DROID2 using Tapatalk
    Edit: here's a link for the osx binary.
    http://dl.opticaldelusion.org/sbf_flash.osx
    Linux:
    Quote Originally Posted by malac0da13 View Post
    Put into bootloader by holding Volume up AND down at same time while powering on
    .. Which I assume is for a Gingerbread-loaded DX.
    A little search on the blog there I found this sbf_flash update blog entry:
    OPTICALDELUSION: sbf_flash updates
    Saturday, February 26, 2011
    sbf_flash updates
    sbf_flash has been updated; there's now a mac os x port, in addition, support has been added for the Defy, Charm and possibly the Atrix.
    sbf_flash [options] [sbf file]
    -f - force; attempt to continue on error
    -v - verbose output (of CDT)
    -r - read CDT information from the phone
    -x - extract sbf file
    -d - download cg from phone
    --cgname [file] - upload/download cgname matches any cgname shown with -r optional file arg for contents
    Examples
    sbf_flash file.sbf
    upload file.sbf
    sbf_flash -v -r
    display detailed CDT information
    sbf_flash -r --boot file.sbf
    sbf_flash -r --boot boot.img file.sbf
    upload boot, optionally using boot.img as the contents
    sbf_flash -r -d --boot
    sbf_flash -r -d --boot boot.img
    download boot, if boot.img isn't specified it will be
    saved using the cgname ("boot") as the filename
    Download
    (* updated Atrix support; many thanks to irc user relaxed)
    Swyped from my RubiX Focused'd Droid X
    I need two DX's.. One to try rom's on and one for MIUI because it's THE daily driver for me so I'm not messin' with it.
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    ill put this in member submitted guides, and itll be reviewed. thanks for ur contribution.
    ill leave it open since the OP is still editing it but please no one else post as of now.
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Update: this was tested by two of the RS members that run OSX, and both of them ended up with phones stuck in the bootloader, rendering them bricked. Please proceed at your own risk.
    Points: 1,752, Level: 24
    Overall activity: 0.6%
    tech_head's Avatar
    4983
    Sillicon Valley, Ca
    257
    I flashed my Dx using Parallels on my Mac with an Xp virtual machine.
    Worked flawlessly.
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Quote Originally Posted by tech_head View Post
    Worked flawlessly.
    With Windows 7 on VMware I get an error. I did notice once I started to flash it went out and got some more drivers the Boot Camp partition and VM partition are the same so perhaps it will work now. But last time I tried:
    bsbabcock's Avatar
    16420
    1,342
    96 times
    I'm thinking right now, the method on an iMac to get it done is via ubuntu with the linux file. Hopefully I'll get some time to load it up and see what this linux biz is all about.. SBF'ing in ubuntu on a mac.. That's got youtube how-to vid written all over it I think, if it's been proven safe under normal conditions.
    Also.. To let you guys know, the sbf_flash developer posted a "combined" file for Linux and OSX.. I would NOT recommend it unless it's determined why you guys had such trouble with the regular OSX version.
    Stinks, I want to go gingy, but not until I get the SBF skill down.
    Rescue Squad
    DebianDog's Avatar
    6359
    4,384
    332 times
    I tried using his SBF on Mac and CONTINUALLY got bus errors. I am not the only one. Look on his site comments section:
    bsbabcock's Avatar
    16420
    1,342
    96 times
    Yeah I asked 1KDS about it.. It's pretty apparent the OSX version has issues.. "back to formula" maybe. Was hoping to read some kind of reply by the dev'.
    I think either you or a few other people have said it, but would you say then using the linux version in ubuntu on a mac would be ok?
  1. Droid X Sync with iMac
    By ckirkpatrick13 in forum Droid X General Discussion
    Last Post: 12-18-2010, 03:10 PM
  2. DX won't connect to iMac via Bluetooth
    By lenrev in forum Droid X General Discussion
    Last Post: 11-07-2010, 09:53 AM
  3. Transferring iTunes music from an iMac to my Droid X
    By PAISANI286 in forum Droid X Help
    Last Post: 10-18-2010, 05:25 PM
  4. Droid X Sync with iMac
    By ckirkpatrick13 in forum Droid X Help
    Last Post: 09-13-2010, 10:27 PM
  5. Welcome To Macintosh On CNBC
    By hatemyEXlovemyX in forum Off-Topic Discussion
    Last Post: 09-11-2010, 01:47 PM
droid x sbf mac
flash sbf droid x mac
how to sbf droid x mac
sbf droid x mac
sbf flash
sbf flash download
sbf flash mac
sbf flash osx
sbf flash.osx
sbf mac
