Need Data throttling explained
This is a discussion on Need Data throttling explained within the Droid X Hacks forums, part of the Droid X Development category; Hi all, What is data throttling? Do I have it? Do I want it? Can I turn it on and off? I'm running apex 1.41 ...
Results 1 to 10 of 18
Thread: Need Data throttling explained
    Points: 1,116, Level: 18
    pharmnatr's Avatar
    29462
    144
    Hi all,
    I'm running apex 1.41 and I see it listed in my apex toolbox.
    What should I do with it?
    TIA
    Al
    Points: 6,283, Level: 51
    Level completed: 67%, Points required for next Level: 67
    jmartinez748's Avatar
    23139
    1,191
    87 times
    if you use alot of data verizon slows your speed so if you apply the data throttle hack your speed wont be changed
    /l ,[____],
    l---L -OlllllllO-
    ()_)-()_)-o-)_)
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Here's some hacks i explain in a lil more detail [GUIDE] Modifications: Risk vs. Reward
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    If u don't use much data, its not needed
    My X has been orangesliced!!
    Points: 3,046, Level: 33
    Level completed: 98%, Points required for next Level: 4
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    I use around 2gigs a month, I take it I'm ok?
    23139
    1,191
    87 times
    Yeah you're good
    /l ,[____],
    l---L -OlllllllO-
    ()_)-()_)-o-)_)
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    You're fine. Apex has it built in so don't worry about it. It won't hurt anything
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    It'll help if u get over 5gigs cause vzw thinks that high which is stupid.. your download speeds wont get throttled if u go over 5 but if u didn't have the hack on it would effect your download speed.. that's all it is really
    Points: 2,193, Level: 28
    Level completed: 29%, Points required for next Level: 107
    monkespit's Avatar
    4694
    Florida
    37
    By built in to apex does that mean the throttle hack is already active, or just that the script is built in to toolbox to more easily turn on?
    Points: 3,351, Level: 36
    Level completed: 1%, Points required for next Level: 149
    spmdroidx's Avatar
    27102
    364
    I don't think I need to but I have a quick question.. say I installed the no throttle and then I had to reflash my rom for some reason, that is without wiping data, do I have to reinstall the no throttle?
  1. data throttling
    By veggiop in forum Droid X General Discussion
    Last Post: 02-21-2011, 04:22 AM
  2. Replies: 0
    Last Post: 02-19-2011, 03:07 PM
  3. Tranquility 3.7 data throttling hack????
    By fersayken2 in forum Droid X Hacks
    Last Post: 02-07-2011, 11:01 AM
  4. Data Throttling ? How to tell ?
    By cynkrzy in forum Droid X Hacks
    Last Post: 01-04-2011, 06:40 PM
apex remove data throttling
data throttling droid x
droid x apex data throttling
droid x data throttling
droid x remove data throttle
how to remove data throttling on droid x
remove data throttle droid x
remove data throttling droid x
what does throttling data mean
what is data throttling
