A Dummies Guide to Android Terminology & Lingo
This is a discussion on A Dummies Guide to Android Terminology & Lingo within the Droid X Hacks forums, part of the Droid X Development category; Here is a well organized post providing abbreviations and terminology so that any one, Droid master or droid newb, can have a quick reference guide ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 46
Like Tree54Likes
Thread: A Dummies Guide to Android Terminology & Lingo
    Your first Group250 Experience PointsTagger Second Class100 Experience PointsThree Friends
    MiXoLoGiSt's Avatar
    266
    SoCal
    262
    55 times
    Here is a well organized post providing abbreviations and terminology so that any one, Droid master or droid newb, can have a quick reference guide to all things droid.
    adb: Android Debug Bridge, a versatile tool lets you manage the state of an emulator instance or Android-powered device
    ADK: Android Development Kit, What people use to develop anything for the droid such as ROM's
    Baseband: In communications and signal processing, the baseband describes signals and systems whose range of the frequencies measured from close to 0 hertz to a cut-off frequency, a maximum bandwidth or highest signal frequency; it is sometimes used to describe frequencies starting close to zero
    Boot Loader: State in which the droid can be flashed from RSD with an appropriate .sdk file that reprograms the phone into a specific ROM or update. This is typically a last resort when the recovery screen cannot be reached to make a much simpler and less risky solution
    Boot Loop: simply means something is preventing the phone from completing it's boot cycle and is stuck between the boot animation and the unlock screen, creating a looped animation. This is often fixed by either reloading a Nandroid, or Reflashing a rom from the Boot Loader.
    Brick or Bricked: Jargon for a completely unrecoverable device, (no more than a brick or paperweight)
    Bug or Software Bug: an Error or flaw in software that produces a failure or unexpected/unwanted result. Typically created from incorrect code, this is why some ROMs are better and smoother running than others because certain developers have taken the time to input "perfect" code
    Busybox: BusyBox is a single multicall binary that packages the functionality of most widely used standard Unix tools, BusyBox provides a fairly complete environment for any small or embedded system.
    ClockworkMod: A recovery program that is often used to apply updates, ROMs, or create a back up or restore a backup file
    De-odex: Apk files have respective odexes that devs use to supposedly save space. Deodexing means you convert it back to a .dex file and put it back inside the apk. This allows you to easily replace files (not having to worry about odexes), but the main point was to deodex services.jar so that you can change all text to different colors (such as the clock color to white) and to deodex services.jar, you need to deodex everything.
    Dev. or Developer: An individual that creates, or alters a file in such a manner as to advance the program
    Flash or Flash Memory: a program technology that can be electrically erased and reprogrammed
    Froyo: Short for Frozen Yogurt, is the latest iteration (2.2) of Android, Google's mobile operating system.
    Kernel: The governor of the CPU usage and Battery output, one can upload certain Kernels to achieve greater performance speed of their device at the cost of some battery life
    Root: Common word associated with giving a user "super user" access to their phones programming and other various aspects that would normally not be possible, also known as "Jailbroken" for iPhone's
    Nandroid or Nandroid Backup: A file typically created in the custom recovery program, such as SPRecovery, that is a carbon copy of whatever state your phone is in before a drastic change is made. the file then can be moved onto or off of the SD card for later use in case something should go wrong in the ROM or Update, or a Boot Loop occurs
    OS: Operating system, I.E. Windows Vista or MAC or ANDROID
    OTA: Over the air...
    Overclocking: Speeding up the CPU past the factory presets to achieve a faster and more responsive device
    ROM: Read Only Memory, a program used to make changes to anything from the look of the home screen, to icons to custom boot animation
    RSD or RSD lite: Remote Software Download, Motorola's own tool in flashing virtualy any type of program, (so long as its in .sbf form) to the Android OS
    Shell or SSH: secure shell or ssh is a network protocol that allows data to be exchanged using a secure channel between two networked devices
    SPR or SPRecovery: A recovery program that is often used to apply updates, ROMs, or create a back up or restore a backup file
    Stock: Simply means an unaltered state, such as when you first purchase your phone from Verizon, or when you do a factory reset
    SU: "Super user", or root permissions
    Theme: A set of icons, backgrounds and app trays that change the ascthetics of the overall look of the droid and its applications
    TUN/TAP: Refers to a network Tunnel, operates within layer 3 packets, or ip packets. Packets sent by a system via a TUN/TAP device are delivered to a user-space program that attaches itself to the device. A user space program may also pass packets into a TUN/TAP device. In this case TUN/TAP device delivers (or "injects") these packets to the operating system's network stack thus emulating their reception from an external source.
    Underclocking: Slowing down the CPU mainly to limit battery usage
    .sbf: Summation Briefcase File
    .apk or APK's: An .apk file extension denotes an Android Package (APK) file, an .apk file can be opened and inspected using common archive tools
    .tar: Similar to a zip file, a tar file archives multiple files into one file
    .tgz: TGZ files are commonly used as install packages for Slackware Linux.
    **Credit to Sam Fisher on DF for this**
    macatk89's Avatar
    37
    142
    8 times
    This should be a Sticky.
    Moderator
    Points: 1,905, Level: 26
    7 days registeredThree Friends250 Experience PointsTagger Second Class100 Experience Points
    Sam's Avatar
    Dirty Dirty
    328
    11 times
    Quote Originally Posted by macatk89 View Post
    this thread is a sticky! (now)
    i figure there will be a lot of people new to android when the DX drops.. this will help a LOT
    Respect is rule #1
    Uughh.. That is my professional opinion.
    macatk89's Avatar
    37
    142
    8 times
    I see that now... it wasn't a sticky yet when I said that! lol
    Moderator
    Sam's Avatar
    Dirty Dirty
    328
    11 times
    nope, but i agreed with you and made it so
    Respect is rule #1
    MiXoLoGiSt's Avatar
    266
    SoCal
    262
    55 times
    Yeah hopefully it will help ease up some questions people may have when we go into our talks with these words lol.
    Points: 1,841, Level: 25
    Level completed: 41%, Points required for next Level: 59
    gardobus's Avatar
    42
    Tucson, AZ
    234
    9 times
    You could add Froyo, Encrypted Bootloader, Apps2SD, and APK to the list.
    Just a few I noticed weren't on there that could confuse some nubs.
    Droid X - Eris - Droid - Storm1 - Curve 8330 - Lots of LG Dumbphones
    Points: 1,368, Level: 20
    Overall activity: 0.0%
    250 Experience Points7 days registeredThree Friends100 Experience PointsCreated Album pictures
    DroidNinja's Avatar
    126
    Everywhere
    64
    Thanks!
    MiXoLoGiSt's Avatar
    266
    SoCal
    262
    55 times
    Quote Originally Posted by gardobus View Post
    APK is on there under .apk towards the bottom. Ill work on adding Froyo to the list and possibly Encryped Bootloader and Apps2SD.
    EDIT: Froyo has been added.
    gardobus's Avatar
    42
    Tucson, AZ
    234
    9 times
    :facepalm: didn't notice it towards the bottom, I looked under A.
  1. DroidX User Guide
    Last Post: 05-05-2011, 06:46 PM
  2. Rooting for Dummies
    By Garemlin in forum Hacking Help
    Last Post: 07-29-2010, 08:58 PM
  3. Droid X User Guide and Manual
    By B16 in forum Droid X General Discussion
    Last Post: 07-09-2010, 01:54 PM
andriod for dummies
android dummies
android dummy
android for dummies
android for dummy
android for dummys
android phone for dummies
android root for dummies
android rooting for dummies
android rooting terminology
android terminology dummies
androids for dummies
droid terminology
droid x terminology
rooting android for dummies
