Heyo,
I used clockwork mod and z4 root to install the APEX 1.4.1 ROM and it was good for a while then half my screen went out. I want to use the warranty replacement. Would SBFing back to stock (Froyo 2.3.340) using RSD Lite 5.3.1 all I would need to do to have it safely exchanged or are there any other considerations?
I really appreciate anyone's input in this. Thanks.
09-25-2011 10:13 PM
Yes, you need to SBF, check out the link in my signature, we have a whole SBF section.
Wow, that was a fast reply. Thanks for the response; I'm gonna go ahead and follow the guide and I'll let everyone know how my warranty exchange went.
Thanks!
Thanks guys for your help. I was able to send it back without any problems.
