What is the network key or wep key to mobile hotspot after rooting?
This is a discussion on What is the network key or wep key to mobile hotspot after rooting? within the Droid X Hacks forums, part of the Droid X Development category; Hello I rooted my X when I try to hot spot my connecting device asks for network key or wep key. Anybody know what to ...
Results 1 to 2 of 2
Thread: What is the network key or wep key to mobile hotspot after rooting?
    Points: 657, Level: 13
    Level completed: 14%, Points required for next Level: 43
    puyalluprealtor's Avatar
    28471
    6
    Hello
    I rooted my X when I try to hot spot my connecting device asks for network key or wep key. Anybody know what to use?
    Thanks
    Points: 1,533, Level: 22
    Level completed: 33%, Points required for next Level: 67
    mcdonnjd's Avatar
    24530
    PA, USA
    65
    You mean with the 3g app? It's whatever you create it to be. Or you can disable it. I'll go check on mine, but pretty sure it prompts you for one first launch.
    EDIT>> OK, first launch it prompts me for a key. After that first launch, it uses whatever I had previously set it to. If you had set it up prior to rooting, it is probably whatever you set it to. To change the key (or possibly see what it is set to, I didn't try checking the show password checkbox when I did it) turn off the hotspot and press the hard menu button and select the Advanced button. This will let you change the encryption and keys.
    EDIT AGAIN>> Then when you go to connect to the hotspot with say, your laptop, when your laptop prompts you for the key, you enter the same thing that you entered into the hotspot app on the phone. If you're using Wireless Tether or Barnacle, the exact steps may vary slightly, think with Wireless Tether it was called settings instead of Advanced, but that's the basics.
  1. 3G mobile hotspot and ps2
    By XxCHAKAxX in forum Droid X General Discussion
    Last Post: 03-02-2011, 03:54 AM
  2. 3G Mobile Hotspot
    By t.crawford714 in forum Droid X Help
    Last Post: 12-13-2010, 12:08 PM
  3. Mobile Hotspot
    By HoweHigh in forum Hacking Help
    Last Post: 12-01-2010, 01:02 PM
  4. Mobile Hotspot Help?
    By HoweHigh in forum Droid X Help
    Last Post: 12-01-2010, 11:48 AM
  5. PDA Net v. 3G Mobile Hotspot
    By ryant35 in forum Droid X Apps
    Last Post: 09-10-2010, 04:09 AM
find iphone hotspot wep key
find wep passphrase on motox phone
how to find network security key for :@ ed0
how to find security code for htc hotspot
how to finde hotspot network key
is there a wep key for iphone hotspot
motorola droid turbo find network security key
motorola razor find network security key
verizon hotspot network security key
where do i find my network key on my verizon hot spot
