[Tutorial] ROMs & Sysctl.conf & other tweaks!
This is a discussion on [Tutorial] ROMs & Sysctl.conf & other tweaks! within the Droid X Hacks forums, part of the Droid X Development category; Updated OP with new info including the change log for his newest .zip version which should work on GB .588, I will test this out ...
Page 60 of 60 FirstFirst ... 10 50 58 59 60
Results 591 to 595 of 595
Like Tree42Likes
Thread: [Tutorial] ROMs & Sysctl.conf & other tweaks!
  1. #591
    Points: 40,405, Level: 100
    Overall activity: 9.7%
    macpro88's Avatar
    20491
    Ohio, USA
    6,712
    314 times
    Updated OP with new info including the change log for his newest .zip version which should work on GB .588, I will test this out and if I could get a few other testers as well! Also, if anyone is on the Liberty GB, please let me know if the instructions have changed at all in Liberty on using the Liberty settings to change the sysctl values.
  3. #592
    I've found the minfree settings to be too aggressive running Gingerbread, which results in early app termination. The sysctl, max window events, and cron cache dump work well with GB though, so feel free to just comment out the minfree function call in /system/etc/init.d/99imoseyon to prevent it from being set on boot
    The default Moto minfree settings seem to be just fine.
  4. #593
    macpro88's Avatar
    20491
    Ohio, USA
    6,712
    314 times
    Quote Originally Posted by DigiK View Post
    awesome, thanks for your input! i will try this out later.
  5. #594
    Points: 629, Level: 12
    Level completed: 58%, Points required for next Level: 21
    Overall activity: 0.0%
    Raytoombs's Avatar
    23681
    11
    Great Read and thank you for the information
  6. #595
    macpro88's Avatar
    20491
    Ohio, USA
    6,712
    314 times
    Updated with OP with some more info, mostly just updates from Mariu's blog title imoseyon.
    Also has a new version out, 7.1, has been tested on Gingerbread but should also work for Froyo ROMs, let me know if it works for those on Froyo.
  1. Nenolod's performance tweaks - sysctl.conf - effective?
    By armedmonkey in forum Droid X Hacks
    Last Post: 03-21-2011, 05:47 PM
  2. Sysctl settings
    By patrick72 in forum Droid X General Discussion
    Last Post: 02-16-2011, 01:40 PM
  3. Kernel Tweaks
    By MXDX in forum Droid X Hacks
    Last Post: 02-06-2011, 11:13 AM
  4. Kernel Tweaks
    By MXDX in forum Droid X ROMs
    Last Post: 02-04-2011, 07:23 PM
  5. X Performance / Memeory tweaks
    By DISCOSTU9 in forum Droid X General Discussion
    Last Post: 07-17-2010, 06:12 PM
Droid x sysctl
android sysctl
android sysctl tweaks
android sysctl.conf
liberty rom tweaks
oom kill allocating task
sysctl android
sysctl config android
sysctl droid x
sysctl liberty
sysctl tweak
sysctl tweaks
sysctl.conf
sysctl.conf android
sysctl.conf tweaks
