This is a discussion on [Tutorial] ROMs & Sysctl.conf & other tweaks! within the Droid X Hacks forums, part of the Droid X Development category; Originally Posted by Marius Well what do you know. Enabling sysctl.conf in liberty settings does not actually alter the conf file. After enabling and rebooting, ...
Root Your DROID X
Everything to know about SBF
DroidXForums Guidelines of Conduct
Show Your Support and Become a Supporting Member Today!
If you are using Liberty you do actually have to enable sysctl support first. This will/should remove the commented out parts. I don't know for certain because I modified my sysctl manually before it was an option but that's how I understood it to work.
Moto Droid X
CM7 / Synergy Theme
O ok, I see. I do have Sysctl Support enabled, a long with the app installed.
How do I actually get to the file so I can see if the values really did change, and so I actually know how to change them manually.
I don't have much experience with using the command line or ADB or whatever it is lol.
Root Your DROID X
Marius, aka. Imoseyon
http://www.imoseyon.com/
Rooted Droid X
Overclocked at 1.35 GHz
A man should look for what is, and not for what he thinks should be.
-Albert Einstein
For anyone interested in undervolting, read Undervolting Guide.
Im unable to adjust my screens brightness now for some reason when I click on it it seems to stay on the advancced setting. Does anyone know why it could be doing this? I have juice defender and thought it might be causing it but I don't see any settings for that there?
Sent from my DROID2 using Droid X Forum App
Sent from the VorteX!
Rooted Droid X
-Albert Einstein
No that didn't work.
Btw, here are the default unaltered vm settings of liberty. Vm. Swappiness of 60 surprises me. I don't think android uses swap.
# sysctl -a | grep vm
vm.overcommit_memory = 1
vm.panic_on_oom = 0
vm.oom_kill_allocating_task = 0
vm.oom_dump_tasks = 0
vm.overcommit_ratio = 50
vm.page-cluster = 3
vm.dirty_background_ratio = 5
vm.dirty_background_bytes = 0
vm.dirty_ratio = 20
vm.dirty_bytes = 0
vm.dirty_writeback_centisecs = 500
vm.dirty_expire_centisecs = 200
vm.nr_pdflush_threads = 0
vm.swappiness = 60
vm.lowmem_reserve_ratio = 32
vm.drop_caches = 0
vm.min_free_kbytes = 2845
vm.min_free_order_shift = 4
vm.percpu_pagelist_fraction = 0
vm.max_map_count = 65530
vm.laptop_mode = 0
vm.block_dump = 0
vm.vfs_cache_pressure = 100
vm.mmap_min_addr = 4096
vm.scan_unevictable_pages = 0
Sorry I posted this in the wrong place
