Okay, so my issue is at home I must be on the edge of two different towers. The one supplying 3G, the other 1x(says extended network, not Verizon). They are constantly going back and forth and it gets frustrating at times. I would rather have 3G even if it's on one bar at times than have only 1-2 bars anyway of 1x. I have been searching online for a way to lock in to the 3G network so that it won't be jumping so much. I haven't found anything helpful, however, I came across this code that I think might help but i need some insight from someone who understands CDMA better than I do. I came from years of GSM with T-Mobile so I understand that much better.
This code is *#*#4636#*#* ...when the window comes up, if u go to "Phone Info" you can scroll down to "Set preferred network type:" and choose from a bunch of options. When I select "EvDo only" it stays on 3G but with no bars, when I go back to "CDMA auto (PRL)", which is what it was on originally, then it goes to 3G with 3 bars but still will bounce to 1x at times. There are other options, but like I said I don't know much in regards to CDMA networks so I could use some help from someone who understands this much better. I would just like to have the option to stay on 3G when at home so it doesn't jump back and forth for frustrating connection issues and poor battery performance. If anyone can explore a little and let me know if I have a good option to this problem I have at home, please let me know and thanx in advance.
my
, even after so many SBFs, ROMs, battery pulls and Clockwork recoveries...
