I need help updating from the old baseband and bootloader???!?!?!?!
This is a discussion on I need help updating from the old baseband and bootloader???!?!?!?! within the Droid X Hacks forums, part of the Droid X Development category; Ok, here is my history with my droid X.. I bought it the day they came out at Verizon... Brought it home, and r00ted it... ...
Results 1 to 10 of 13
Thread: I need help updating from the old baseband and bootloader???!?!?!?!
    Points: 1,044, Level: 17
    Level completed: 44%, Points required for next Level: 56
    chipg07's Avatar
    2445
    22
    Angry I need help updating from the old baseband and bootloader???!?!?!?!
    When the leaked 2.2 came out, I installed it...
    I installed every rom that was released, to try them out..
    When the 2.2 SBF came out, I used it to wipe the phone clean, and install my favorite rom of choice, so it was less cluttery..
    During that time I have no idea, what baseband and bootloader I started off having, but here is what I have now..
    Bootloader - 30.01
    Baseband - BP_C_01.09.06P
    I want to update to the newest bootloader and baseband, because my phone doesn't work right with some roms, and I think it is caused by one of those two.. When I install certain roms, I won't name them, they make my cell radio usage skyrocket and make my battery drain 3-4 times faster... I am convinced it's because of the baseband, which is the radio (although i know nothing about android)..
    People have dismissed it as a display issue, but I have used every rom released for long enough, that if one lasts 18+ hrs on a full charge, and one doesn't last 5 hrs on a full charge, it's either something wrong with the rom, or my phone, and since other people comment how much they love the same roms that won't work right for me, I have to assume that it is my phone...
    I have done everything I can think of, including trying to sbf back to 2.1 and then do the OTA update, which resulted in a brick, and having to sbf back to 2.2..
    Can someone, anyone, who has any kinda clue how to update the baseband, please help me?
    I appreciate all the help, but I don't need a bunch of questions about what I have tried, if I wiped, etc..... I have done ALL that
    Thanks in advance for any help on this subject...
    Jcshannon05's Avatar
    1703
    20
    If it was me I would flash the newest sbf to 2.2 and go from there. And another thing... All Droids react differently to any rom. Some people get better battery life and some don't. I know it kinda sucks but u just gotta find the rom that works the best with your phone. I'm running Rubix 1.6 without any theming done. Its running fast with 5 homescreens full of Widgets.
    chipg07's Avatar
    2445
    22
    I refuse to believe that. Same hardware, same bootloader, same kernel, same rom = same results. I will try the sbf and then ota update. Thanks.
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Quote Originally Posted by chipg07 View Post
    I updated mine the other night since I hadn't bothered to take the OTA update and was still on the leak. The 30.01 bootloader is 2.1, so you need to use the 2.1 sbf first. After flashing the 2.1 sbf, boot it up and install the OTA update. That will get you to the 30.03 bootloader in 2.2.
    Edit: I see now that you say you have tried this, but 30.01 is the 2.1 bootloader, and that's the only way I know to update it.
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    193
    11 times
    What C Dippa said! He's completely correct. Only way I would know how to update those. That's what I did and I know that works.
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
    chipg07's Avatar
    2445
    22
    Ok. I tried using the 2.1 sbf. It ran fine, finished, but then I was stuck at the bootloader with an error. Couldn't do anything.
    Also, when I use the 2.2 sbf and then try the ota it says I am up to date.
    chipg07's Avatar
    2445
    22
    Update...
    I still cannot get the 2.1 sbf to work, and still have the 30.01 bootloader, and xxxxx06 baseband.
    NOTHING Works.
    This sucks.
    2.2 sbf works fine, but won't update my bootloader and baseband.
    Anyone? Bueller?
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Sorry to hear that man, the file I used for 2.1 was "the_gift.zip". Is that the file you've got?
    If not, I'd be happy to post a link if you wanna try that one.
    Sent from my DROIDX
    chipg07's Avatar
    2445
    22
    Yes. That is the one I used. The gift.
    ArthurIhde's Avatar
    15367
    169
    hmmm,thanks for the sharing.
    Just bought a droid X
  1. Can't get into Bootloader, please help!
    By Chaplain69 in forum Droid X Help
    Last Post: 11-03-2010, 11:40 PM
  2. DroidX Bootloader
    By tx3 in forum Droid X Hacks
    Last Post: 09-28-2010, 01:11 AM
  3. How to downgrade baseband back to 1BP_01.09.04P
    By polakson in forum Droid X General Discussion
    Last Post: 09-23-2010, 03:15 PM
  4. App Updating
    By treyinga in forum Droid X FAQs
    Last Post: 09-11-2010, 07:15 PM
  5. Bootloader Petition
    By dard12 in forum Droid X General Discussion
    Last Post: 07-30-2010, 11:56 AM
android outdated baseband
droid x 30.01 bootloader
droid x baseband flash
droid x baseband update
droid x bootloader 30.01
droid x saying bootloader 30.01
droid x updating baseband to .13
how to fix my droid x bootloader 30.03#gsc.tab
restoring baseband update on droid x
update droid x bootloader 30.01
