Is there any way to use Droid X with carrier other than Verizon?
This is a discussion on Is there any way to use Droid X with carrier other than Verizon? within the Droid X Hacks forums, part of the Droid X Development category; I bought Droid X on EBay and now want to use it with different carrier (not Verizon). Phone interface doesn't have any option to exchange ...
Results 1 to 10 of 10
Thread: Is there any way to use Droid X with carrier other than Verizon?
    I bought Droid X on EBay and now want to use it with different carrier (not Verizon). Phone interface doesn't have any option to exchange settings for built-in EV-DO modem (dialing number, username, password, etc). phones running Android and build by HTC have easy access to modem internet settings. My Droid is running 2.2 version.
    Help, plz!
    Points: 2,017, Level: 27
    Level completed: 12%, Points required for next Level: 133
    Strikeir13's Avatar
    12326
    7
    Don't think this is possible...
    boost192's Avatar
    8437
    95
    The only other network I think is cricket or metro pcs but you have to flash it!
    Points: 1,649, Level: 23
    Level completed: 49%, Points required for next Level: 51
    250 Experience Points31 days registered100 Experience PointsCreated Album pictures7 days registered
    l_n's Avatar
    13051
    Knoxhell, TN
    77
    11 times
    Try ##PROGRAM [send] 000000 [verify] from the dialer
    Were you able to flash your phone?
    veNADEtta's Avatar
    29634
    Its a cdma phone. Not very familiar with this type of stuff, but you might be able to run it on sprint. Highly doubt it, but do some research.
    Points: 1,955, Level: 26
    duro78's Avatar
    20949
    169
    No offense but don't you think you have the process a little backwards, research then purchase. Either way goodluck
    Droid X - Rooted Z4 - OTA 340 - Gummy Jar 2.5 - Theme Watermark - ADW Ex
    Points: 1,752, Level: 24
    Overall activity: 0.6%
    tech_head's Avatar
    4983
    Sillicon Valley, Ca
    257
    Sprint is CDMA but you will not be able to use it on Sprint because you need to add the MEID/ESN to their database and flash the phone.
    You could probably flash the phone but you aren't going to add it to their database in this life.
    The only options are Cricket and MetroPCS.
    johnnyboy14981's Avatar
    26961
    5
    Yes you can fully flash this phone to cricket. I am using one with the Apex rom and ALL features working. It will take some research but it's definitely possible. I believe that Cricket is the only network that will allow non branded esn's on their network. Just make sure you activate your plan with the adr60 $55 android rate plan. It's completely unlimited for $55 a month, and it will make the flash a bit easier when you get into programming data and mms. Good luck. And here's a freebie don't edit the modem settings directly from the phone. Get hardware virtual serial port use that combined with qpst with the phone on pc mode to change all the settings you need to. There are full guides out there. This phone actually isn't all that difficult to do.
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    A guide on how to flash to cricket was posted a couple of days ago. It should greatly simplify the process.
  1. Sent by Verizon Droid
    By woody5 in forum Droid X Rescue Squad
    Last Post: 08-12-2011, 07:19 AM
  2. new to Verizon and droid x
    By pilotbike101 in forum Droid X Help
    Last Post: 10-23-2010, 02:31 PM
  3. Replies: 14
    Last Post: 09-04-2010, 08:38 PM
  4. My Verizon app on Droid X
    By rgb24 in forum Droid X General Discussion
    Last Post: 07-18-2010, 05:57 PM
  5. Replies: 3
    Last Post: 07-10-2010, 04:36 PM
can i transfer my droid from verizon to another carrier?
can you use motorola x on sprint's network
droid service providers
droid x carriers
droid x service providers
flash droid x to sprint
flash verizon android to sprint
is there another phone service other than verizon
motorola droid service providers
motorola droid x carriers
