[HOW TO] Use Droid X Bootstrap
This is a discussion on [HOW TO] Use Droid X Bootstrap within the Droid X Hacking Guides forums, part of the Droid X Development category; Droid-Xer, seriously, thank you for the write up. We all have these apps on our phone but don't know how to use it to its ...
Page 2 of 31 FirstFirst 123412 ... LastLast
Results 11 to 20 of 309
Like Tree104Likes
Thread: [HOW TO] Use Droid X Bootstrap
    Points: 2,741, Level: 31
    Level completed: 94%, Points required for next Level: 9
    Pensacola32526's Avatar
    6225
    Pensacola, FL
    296
    Droid-Xer, seriously, thank you for the write up. We all have these apps on our phone but don't know how to use it to its full potential.
    Sean Wristen likes this.
    Still my , even after so many SBFs, ROMs, battery pulls and Clockwork recoveries...
    Rooted, Gingerbread .602, VorteX RC1, Trident Electra & 3200 mAh battery.
    USMC 2000-? Oorah!
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Quote Originally Posted by Pensacola32526 View Post
    No problemo. I was told it was in rooolers guide, but that's some heavy reading. Your legs go numb sitting on the throne that long! I just put it out cuz I was getting quite a few PMs on using it. So enjoy.
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Boo, lost sticky but got my first guide
    Points: 82,727, Level: 100
    250 Experience PointsYour first Group31 days registered100 Experience Points7 days registered
    wicked's Avatar
    15645
    San Jose CA.
    5,245
    728 times
    Quote Originally Posted by Droid-Xer View Post
    great job on the write up! only reason you lost sticky is because the thread got moved to the proper designated
    forum for guides, therefor no longer needs a sticky. Keep up the good work man!
    Droid-Xer likes this.
    Points: 146,349, Level: 100
    Overall activity: 71.4%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    I only removed your sticky because I had a hacking tutorial guide section created for just these types of guides and moved it there. It won't get lost. Trust me.
    If it is any consolation yours is the first guide I moved here.
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Ya just saw that guys. Thanks
  8. #17
    Points: 2,962, Level: 33
    Level completed: 42%, Points required for next Level: 88
    Overall activity: 7.0%
    Ro6d33zy's Avatar
    7356
    459
    Now, you're saying that if you delete BSR through Root Explorer, you can still restore a backup through Stock Recovery?
    Where does it give you the option to Restore, within the Stock Recovery?
    Sent Via: Droid X- Rooted @1.35 Ghz! Rom> Rubix Blurry
    >(: | _]=
  9. #18
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    No you will only need to remove bootstrap to take an update or if you need to take the phone into VZW. After you take the update just use the link in my signature or post 1 to download the boosttap app again. If you take the update, its not a good idea to restore a backup from an older version. The backups are stored on your SD card so you will need bootstrap to restore them.
    The stock recovery is only used if you're stuck in a boot loop. Boot into stock recovery, wipe data/cache, factory reset, and then once phone boots up properly then you can load your last backup by downloading bootstrap again, if it gets erased.
  10. #19
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    @Droid-Xer
    So you do have to remove bootstrap to update? I have been finding conflicting info everywhere, with no definative answer. I had found a nandroid backup of someones 2.3.151 on BL 30.04(like mine & was going to use it to get back to stock) and then update to 2.3.340. The only things on the backup I dl'ed is z4root, bootstrap, and rom manager. Are you saying BS would need to be removed b4 phone will accept the ota, and if so, can I bypass installing the 2.3.151 backup?
  11. #20
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Quote Originally Posted by skennelly View Post
    @Droid-Xer
    the bootstrap has to come off. see here
    [HOW TO] Install and Remove Bootstrap Recovery
  1. Bootstrap
    By mrclean2828 in forum Droid X Rooted Issues
    Last Post: 12-10-2010, 09:55 AM
  2. Dx bootstrap
    By mrclean2828 in forum New Member Introductions & Site Assistance
    Last Post: 11-11-2010, 08:11 PM
  3. Droid X on reboot....boots into Bootstrap everytime HELP!
    By ShadowDroid in forum Droid X Hacks
    Last Post: 10-10-2010, 11:18 PM
  4. Droid X Bootstrap Recovery by Koush
    By JMuldrow in forum Droid X General Discussion
    Last Post: 08-21-2010, 03:17 PM
  5. Replies: 11
    Last Post: 08-20-2010, 08:04 PM
Droid X Bootstrap
Droid X Recovery Bootstrap
Droid X Recovery Bootstrap apk
bootstrap droid x
bootstrap recovery droid x
droid x bootstrap apk
droid x bootstrap recovery
droid x bootstrapper
how to use droid 2 bootstrapper
how to use droid x bootstrap
