3G Not working!
This is a discussion on 3G Not working! within the Droid X General Discussion forums, part of the Droid X Discussion category; Hey folks, I'm hoping someone can help me with this random problem that started happening this morning. For some reason, my 3G stopped working. I ...
Results 1 to 10 of 15
Thread: 3G Not working!
    groovejedi's Avatar
    9639
    52
    3G Not working!
    Hey folks,
    I'm hoping someone can help me with this random problem that started happening this morning. For some reason, my 3G stopped working. I use the SwitchPro widget on my homescreen, and when I tap 3G to turn it on, it looks like it turns on but as soon as I open a web browser, it says that no internet connection can be found. I can make phone calls but cannot browse the internet. I tried a battery pull but that didn't solve the problem. Any idea why my 3G would suddenly stop working?
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Not sure - but have you tried to toggle into "airplane" mode and then back out...
    groovejedi's Avatar
    9639
    52
    Yes, I tried that, no luck
    groovejedi's Avatar
    9639
    52
    Solved - Somehow "Data Enabled" got unchecked. Now idea how.
    20,509
    885 times
    Quote Originally Posted by groovejedi View Post
    Cool - glad it was that simple ...and it is now working..
    Points: 1,189, Level: 18
    Level completed: 89%, Points required for next Level: 11
    ganguess's Avatar
    15965
    Where is that so I can check mine I am having the same problem
    Thanks
    Points: 1,133, Level: 18
    Level completed: 33%, Points required for next Level: 67
    vnom2112's Avatar
    18016
    Just in case someone else runs into this problem. I also found that data enabled was unchecked. Checking that option fixed the problem. This option is located in Settings->Battery&Data Usage->Data delivery->Data enabled. This is the process for android 2.3
    Points: 154, Level: 3
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 0.0%
    mshakir's Avatar
    47677
    Sep 2011
    Hey folks,
    Try this, I just got my 3G service working with the help of VZW tech support
    I am using droid X with gingerbread 2.3.3
    First check
    setting ->wireless and network setting
    go to the bottom and select
    mobile networks
    The screen should say 'System Select' and nothing else. If you click this option, next page, make sure it is set on automatic, mine does.
    next go to settings
    settings -> battery & Data Manager -> data delivery
    enable all top three options
    background data
    data roaming(not sure if you need to do this, I did it per tech instructions)
    data enabled ( this should do the trick)
    Hope this helps.
    Points: 9,019, Level: 63
    Level completed: 90%, Points required for next Level: 31
    Overall activity: 2.5%
    firefighterguy's Avatar
    8489
    Colorado
    1,559
    46 times
    Quote Originally Posted by mshakir View Post
    ....make sure it is set on automatic, mine does.
    You can also try "Home Only" if one feels like it. I have found that it does a better job or retaining a signal lock (still faulty as hell. But still). Home Only isnt going to affect going out of town/state etc. As long as you have a national plan (as all of us should). Your *Home* is your home country when on a national plan.
    ____________________
    "King of the Self-Edit'"
    "Patriotism is supporting your Country at all times. And your government only when it deserves it" --Mark Twain
    "King Of The 'Self-Edit'"
    Points: 48,761, Level: 100
    Overall activity: 17.2%
    gbrinn's Avatar
    38696
    Headed to Duke University Hospital
    17,707
    727 times
    I figured "Home" was just Verizon's network, since there's also "Affiliated Networks" listed and then "Automatic".
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
  1. GPS not working
    By droidkat in forum Droid X Help
    Last Post: 10-22-2011, 03:08 PM
  2. GPS not working.
    By sicRage in forum Droid X Help
    Last Post: 10-05-2010, 12:45 PM
  3. Is Facebook Working on Your X/
    By Cigator in forum Droid X Help
    Last Post: 09-25-2010, 01:31 PM
  4. Landscape txt not working.
    By patsceltsbosox in forum Droid X Help
    Last Post: 07-27-2010, 10:47 PM
  5. GPS working?
    By Djnardu in forum Droid X General Discussion
    Last Post: 07-27-2010, 03:54 AM
3g not working
3g not working droid
3g not working on android
3g not working on droid x
android 3g not working
droid x 3g not working
droid x internet not working
why is 3g not working
why is my 3g not working
