Droid will not turn on....
This is a discussion on Droid will not turn on.... within the Droid X General Discussion forums, part of the Droid X Discussion category; When I push the On button, all i get is the "M" symbol for a few seconds and then it goes out and the screen ...
Results 1 to 7 of 7
Thread: Droid will not turn on....
    When I push the On button, all i get is the "M" symbol for a few seconds and then it goes out and the screen is black...
    The phone will ring when i get a call, but the screen stays black, so i can not answer the phone.
    thoughts?
    thanks
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Have you attempted a battery pull / reboot and what is / was the charge of your battery?
    Glen's Avatar
    14474
    Tampa, FL
    11
    I would suggest the battery-pull option as well. Had something similar happen just after the Froyo 2.2 update and that fixed it up.
    - Glen
    I got it working!
    Quote Originally Posted by jimbosteel View Post
    thoughts?
    thanks
    I exactly had same problem. What I did is, removed the battery, removed the SD card and placed my phone in charging(not USB, must be wall charger) and waited for "M"(should be big F) symbol to appear. Then place the battery(don't remove from wall charger) and you should see "charging battery" animation. Now restart the phone(don't put SD card in and don't remove from wall charger) and it should start normally.
    I tried to put SD card in and it didn't work for me, so I went to Verizon store and asked for replacement and it is on it's way and I should get it on Monday.
    I haven't tried to dig into root problem but should be doing this weekend. I'll keep posting on this!
    Hope same steps may work for you.
    Points: 800, Level: 14
    Level completed: 50%, Points required for next Level: 100
    ajdietz's Avatar
    16008
    8
    I have had the same problem, and found this solution. It works like a charm for me. Be sure to follow the instructions exactly:
    Instructions…
    1. Turn your phone off.
    2. Hold down “Home” and press “Power” until the Motorola logo appears.
    3. Release ”Power” and continue to hold “Home” until an exclamation appears.
    4. Release “Home” and press the “Search” button once.
    5. Your phone will now enter recovery.
    To get out of it, simply use your volume up and down buttons until “reboot system now” is highlighted and then press the camera button. Your Droid will reboot and all will be well with the world.
    How to: Boot into Recovery on the DROID X - Droid Life: A Droid Community Blog
    ArthurIhde's Avatar
    15367
    169
    yes i have the same issue
    Just bought a droid X
    Tagger Second Class
    ThuhGibstuh's Avatar
    36416
    Thanks man! this worked!!
  1. OMG~ My Droid Won't Turn on.
    By zzang2gee in forum Droid X Help
    Last Post: 10-03-2013, 08:32 AM
  2. Google GPS. Any app for audible turn by turn?
    By set theorist in forum Droid X Apps
    Last Post: 07-03-2011, 11:20 AM
  3. Help ! Droid X won't turn on ! Someone call 119 !
    By Force in forum Droid X Help
    Last Post: 01-04-2011, 02:16 PM
  4. Replies: 0
    Last Post: 10-03-2010, 10:29 AM
  5. Turn your Droid X into a Media Server
    By syrnett in forum Droid X General Discussion
    Last Post: 09-08-2010, 03:34 PM
Droid not turning on
droid phone will not turn on
droid will not turn on
droid x not turning on
droid x will not turn on
motorola droid not turning on
motorola droid will not turn on
motorola droid x will not turn on
my droid will not turn on
my droid wont turn on all the way
