My Droid X doesn't charge (sometimes)
This is a discussion on My Droid X doesn't charge (sometimes) within the Droid X General Discussion forums, part of the Droid X Discussion category; Okay, this is very awkward. I plugged in my Droid X last night thought it was charging and I unplugged it today and it was ...
Results 1 to 10 of 13
Thread: My Droid X doesn't charge (sometimes)
    Crazy's Avatar
    7034
    54
    I plugged in my Droid X last night thought it was charging and I unplugged it today and it was still at 20% from where it was last night.
    Wth is up with that?! I removed the usb and connected it again and it started to charge again. It happened to be about two times before as well.
    Is my Droid X defected or what? :O If this continues, I'll probably consider getting a new replacement.
    The-X-factor's Avatar
    9673
    132
    bad charge port? it happens..
    DaRkL3AD3R's Avatar
    8807
    91
    8 times
    This same thing happened to mine, my gf's, my brothers (both of them) and my cousin. It was with each owns cables, so not like the cables are defective. I haven't seen it happen on mine in a long time (knock on wood) nor have I heard from anyone else seeing it in awhile. I guess the ports were just needing some break in period like a new pair of shoes :P
    Points: 1,323, Level: 20
    Level completed: 23%, Points required for next Level: 77
    kwikgrizz's Avatar
    7918
    20
    I was having the same problem. I don't know if this was the problem or not but mine is charging fine now. I changed task killer app to Advanced task killer so i am wondering if the app Task manager was telling it not to charge
    RugerDog's Avatar
    7010
    12
    Just make sure that when you plug in your USP cable that you are connected at both ends. If your rough with your ports you will end up with a sloppy connection.
    Points: 1,162, Level: 18
    Level completed: 62%, Points required for next Level: 38
    TrojanDroid's Avatar
    3637
    California
    93
    Are you using the wall charger?
    Hooking the USB cable to a computer port?
    This phone requires a pretty high amperage to charge, so for me it takes forever when I use my computer to charge it, but it does OK if I use the wall wart. It does NOT necessarily do OK if I use a different phone charger with the same kind of connectors (like my old BB charger or something like that)
    Crazy's Avatar
    7034
    54
    I noticed mine always charges when I have my phone on standby mode and whenever my phone is turned on, it sometimes does not charge. So idk if that's a bug or anything. I handle my cables very carefully so I doubt that has anything to do with it.
    BSmith's Avatar
    58
    Southern Pines, NC
    15
    I couldn't figure out why my screen wasn't staying on when in the cradle/multimedia dock the other night. I didn't care that much so I didn't mess with it but I noticed when I got to the office that my battery was only 60% charged.
    I saw it happen one other time and popped it out and put it back in and all was fine.
    vinyl66's Avatar
    8003
    51
    Once I deleted ATK my charging problem dissapeared.
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    Ditch ATK and you will see improvement.
  1. Droid X won't charge
    By zenlike in forum Droid X Help
    Last Post: 12-29-2010, 01:18 PM
  2. Replies: 9
    Last Post: 10-08-2010, 02:37 AM
  3. Droid X 'rebooting' but doesn't appear to be
    By shamy in forum Droid X Help
    Last Post: 08-18-2010, 03:58 PM
  4. Computer Doesn't Read My Droid X
    By DroidX04 in forum Droid X Help
    Last Post: 08-05-2010, 09:08 PM
  5. Safe to charge Droid X 24/7?
    By dsuh in forum Droid X General Discussion
    Last Post: 07-29-2010, 01:04 AM
Why isn't my droid x charging
droid 2 doesn't charge
droid doesn't charge
droid x doesn't charge
droid x isn't charging
droid x won't charge
my droid isn't charging
my droid x isn't charging
why isnt my droid x charging
why wont my droid x charge
