How to Stop Running Apps I dont Use?
This is a discussion on How to Stop Running Apps I dont Use? within the Droid X General Discussion forums, part of the Droid X Discussion category; Nice, I did not know about that. You guys just need to pick your poison. It probably takes longer to reply to this thread than ...
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: How to Stop Running Apps I dont Use?
    markiepaul's Avatar
    470
    So. Ill.
    157
    Nice, I did not know about that. You guys just need to pick your poison. It probably takes longer to reply to this thread than to root.
    FRIENDS FOREVER
    MIUI gets me hot like Kelly.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    I will first post the link to the thread that discusses the Android OS.... Androidology (& Android OS Memory Management [task killers])
    Secondly, there are a few "task killer" type apps you can check into...not sure that any of them will permanently stop the apps from starting...
    SystemPanel - SystemPanelLite Task Manager v1.0.6 Application for Android | Tools
    Task Killer - TasKiller Android App Review by AndroidTapp.com | Android Tapp. Android App Reviews
    Advanced Task Killer - Advanced Task Killer Android App Review by AndroidTapp.com | Android Tapp. Android App Reviews
    Points: 1,236, Level: 19
    Level completed: 36%, Points required for next Level: 64
    carolnim's Avatar
    3909
    68
    Is there any "downside" to rooting the phone? I am not terribly tech savy and would not like to mess something up that I cannot fix.
    20,509
    885 times
    Quote Originally Posted by carolnim View Post
    No downside - there are easy root methods now...however, feel comfortable in doing it...I would check out the "Hack" area and read, read, read...
    hondatech33's Avatar
    8714
    Quote Originally Posted by cosshog View Post
    Is there a way to stops apps permanently that I do not use (ex: skype.) I go into running apps and stop them at the beginning of the day but the next day when I reboot the phone(which I do every morning when I take off the charger) They start running automatically and it is kind of a pain to go in and shut them off every day I just want to stop them permanently.
    Thanks for any help
    i have only had my phone for a week but was wondering where do you find what apps are running so you can stop them?
    20,509
    885 times
    Quote Originally Posted by hondatech33 View Post
    Phone settings (homescreen, hard menu key), applications, running services, tap on app and it will show a popup box asking if you want to force stop the process...or also - phone settings, applications, manage applications, select all or running (option accessed by your hard menu key in 2.1 I believe), open an app and you will see a force stop option..
    And welcome to the forums!!
  1. Apps that I never started running in the background
    By timborocksloud in forum Droid X Help
    Last Post: 09-08-2010, 01:56 AM
  2. running apps. why so many
    By blueoval95 in forum Droid X Help
    Last Post: 08-30-2010, 10:44 PM
  3. when should I stop installing apps?
    By larzx in forum Droid X Apps
    Last Post: 08-22-2010, 03:14 PM
  4. Any way to stop the built-in motorola apps?
    By y10k in forum Droid X Apps
    Last Post: 08-12-2010, 04:15 PM
  5. Are these apps running?
    By PittDucky in forum Droid X General Discussion
    Last Post: 07-16-2010, 04:05 PM
android force stop
droid 2 kill services and running apps
force stop on droid
how do i stop apps from running on my android
how do i stop apps from running on my droid
how to stop apps from running on droid
how to stop apps on droid
how to stop apps on my x2 droid from running
what does force stop mean
what does force stop mean on droid
