Battery drained fast!!!
This is a discussion on Battery drained fast!!! within the Droid X General Discussion forums, part of the Droid X Discussion category; Had 90 percent when I left at 7am this morning. It just went dead five hours later. And had very minimal use. A few texts ...
Results 1 to 10 of 19
Thread: Battery drained fast!!!
    Points: 123,642, Level: 100
    Overall activity: 92.9%
    Garemlin's Avatar
    15
    Delaware
    3,846
    357 times
    Had 90 percent when I left at 7am this morning. It just went dead five hours later. And had very minimal use. A few texts and maybe twenty minutes of net. I keep my phone in a locker at work and.that has always caused issues with my droid. But it always lasted at least until i got off work. We'll see how it goes after a fresh charge.
    Points: 3,860, Level: 39
    Level completed: 40%, Points required for next Level: 90
    anomaly's Avatar
    573
    151
    if the locker is metal the droid might be freaking out trying to grab a signal?
    just my $0.02
    Your first GroupThree Friends250 Experience PointsTagger Second Class100 Experience Points
    B16's Avatar
    12
    Somewhere, SC
    446
    97 times
    Try ATK and cleanoid.
    Follow me on TWITTER!
    Please read this before you root your X!
    Feel free to thank me if you think I helped. (<<<The button is on this left)
    Check out my new BLOG!
    karmajay's Avatar
    237
    USF, FL
    138
    I've heard a few stories of the wall charger being bad so it is not getting a good charge. Try directly to the computer or car charger and see if you have same draining problem. Also, kill any moto widgits you aren't using.
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    I swapped out my battery already - it failed to charge (even the UI showed the battery as discharging rather than charging).
    Points: 1,231, Level: 19
    Level completed: 31%, Points required for next Level: 69
    KDogg's Avatar
    575
    29
    yesterday mine went to 30% pretty quick (was playing with it all morning), so i turned it off for about half an hr, then it was back up to 70%... today, i've played with it significantly less and had battery saver mode on all day, and still down to 30% less than 7 hrs after unplugging. i reboot and after less than 30 seconds, back up to 70%. WTF?
    interestingly enough, the main battery page says "2h 2m xx since unplugged," even though it's been way longer than that (the cumulative total on the 4 detail screens is correct though). double-wtf?
    dimachka's Avatar
    145
    Quote Originally Posted by KDogg View Post
    Similar issue, earlier today i had 40% left and wanted to reboot because of an unrelated reason. When i turned the phone back on, it was suddenly reporting 70% and im still at 60% left now. Not sure whats up.
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    This is all standard with a new Android phone, guys. You have to either calibrate it yourself or wait over time for it to calibrate itself. Your choice. If you don't want to calibrate it, then expect some unreliable indications of battery life.
    hendrix's Avatar
    152
    As far as putting the droid in your locker. Turn on airplane mode before putting it in your locker. Then it won't be struggling for a signal all day.
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    Quote Originally Posted by hendrix View Post
    That's a pretty good idea!
  1. Extended Battery + Case?
    Last Post: 04-08-2011, 09:34 PM
  2. how long should i charge my BATTERY?
    By axelaTDK in forum Droid X General Discussion
    Last Post: 08-15-2010, 02:05 PM
  3. Battery stopped charging
    By Jaxidian in forum Droid X Help
    Last Post: 07-21-2010, 01:06 PM
  4. DROID X Battery Life
    By movadoevo8 in forum Droid X General Discussion
    Last Post: 07-20-2010, 01:43 PM
  5. Battery Charger/Cable
    By dard12 in forum Droid X General Discussion
    Last Post: 07-16-2010, 05:18 PM
battery draining fast on droid x
droid x battery drain
droid x battery draining fast
droid x battery draining quickly
droid x battery drains fast
droid x battery drains quick
droid x battery drains quickly
droid x battery is draining fast
droid x draining battery fast
why is my droid x battery draining so fast
