QUESTION: managing files on droid x...how to transfer files between computer and DX?
This is a discussion on QUESTION: managing files on droid x...how to transfer files between computer and DX? within the Droid X General Discussion forums, part of the Droid X Discussion category; are you guys using the vcast manager? or just plugging the droidx via the oem usb cable? im having a hard time figuring this thing ...
Results 1 to 8 of 8
Thread: QUESTION: managing files on droid x...how to transfer files between computer and DX?
    Points: 1,364, Level: 20
    Level completed: 64%, Points required for next Level: 36
    1 year registered3 months registered31 days registered100 Experience Points7 days registered
    fongaroos's Avatar
    3358
    26
    im having a hard time figuring this thing out... the file management isnt very intuitive...
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    I use the usb cord! I just save any files I want to my PC and be on my way lol
    Droid Does!!!
    Points: 2,006, Level: 27
    Level completed: 4%, Points required for next Level: 144
    Btango05's Avatar
    6029
    106
    Mostly I use the USB cable. I have tested bluetooth file transfer which worked well but I wouldn't want to transfer several files using bluetooth, just the occasional photo. If you're looking for a music/video manager so you can sync music/vids I use doubletwist. Some say tunesync works but I believe it only works with os x 10.6 I'm still running 10.5 on my mac.
    What are you trying to do?
    fongaroos's Avatar
    3358
    26
    Quote Originally Posted by didiwags View Post
    i tried that but sometimes there are folders that show up on the astro app on my DX that DONT show up when i plug the DX into my computer...
    weird?!
    fongaroos's Avatar
    3358
    26
    i guess i would just like to transfer some MP3s and videos to my DX.
    at this point, i have a "media" folder and one "audio" and one "video" subfolder.
    the videos work fine because i just use the free version of rockplayer. that seems to work pretty well.
    as for the music, i have tried using the native mp3 player but it doesnt load all of my music...
    i am thinking perhaps it is because under "audio" i have multiple subfolders...
    does this make sense?!
    Points: 1,261, Level: 19
    Level completed: 61%, Points required for next Level: 39
    250 Experience PointsCreated Album pictures31 days registered100 Experience Points7 days registered
    QuantamPulse's Avatar
    534
    Dania Beach, FL
    47
    Quote Originally Posted by fongaroos View Post
    I just loaded a bunch of music over onto my phone and the default music player is picking up everything fine. I have them in the Music folder on the main page and then broken down into sub-folders for artist and further sub-folders for albums. That being the case I don't think the sub-folders would be your problem.
    Btango05's Avatar
    6029
    106
    Yeah makes sense. I forget what format you want to use if you're trying to add music and say for instance you have two albums from the same artist. I would suggest looking for a media manager in the market. I use doubleTwist it can sync playlist from iTunes to the X with album art too!
    534
    Dania Beach, FL
    47
    I used the format I showed above and have some folders for artists with 5 - 6 sub-folders for albums. Everything display perfectly in the stock player.
    The only thing I did was connect via the USB cable and drag and drop the files onto the SD card. Cover art and everything comes over just fine without the need for any special software. All that matters is that your music is properly tagged on your PC before moving the files over.
  1. Replies: 6
    Last Post: 09-01-2010, 12:46 AM
  2. DROID X - Transfer files to/from my computer
    Last Post: 08-27-2010, 11:38 AM
  3. Why can't we zip files on the droid x?
    By realace in forum Droid X General Discussion
    Last Post: 08-09-2010, 01:54 PM
  4. Droid X Source files
    By discstu37 in forum Droid X Hacks
    Last Post: 07-30-2010, 04:24 PM
  5. Replies: 5
    Last Post: 07-16-2010, 03:26 PM
droid x file transfer
how do you manage fils droid x
how to access files on droid x
how to add documents to my droidx
how to download files on droid x without sd card
how to save files on droid x
save droid x files to computer
transfer files from droid x to pc
transfer files to droid x
transfer mp3 to droid x music
