Friend needs helpppp!!!!
This is a discussion on Friend needs helpppp!!!! within the Droid X General Discussion forums, part of the Droid X Discussion category; my friend just got a droid x mb810 and it runs super slow. We cleared the cache through startup and it still runs horribly it ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By sd_shadow
  • 1 Post By Toad
Thread: Friend needs helpppp!!!!
    Exclamation Friend needs helpppp!!!!
    it is my understanding that one has to root this thing in order to get any kind of improvement on performance and speed.
    I was just wondering which rom would be best for the mb810 and which guide to use.
    ANY HELP IS GREATLY APPRECIATED!!!
    Points: 18,645, Level: 86
    Level completed: 59%, Points required for next Level: 205
    Overall activity: 80.0%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by theweatherman View Post
    The Droid X is very old, in Android years it's like a 150.
    There could be hardware failure, bad battery, maybe a bad app, or other software issue.
    To install a custom rom
    1. Root [ROOT] Framaroot, a one-click .APK to root watch
    2. Install/Use Droid modified X or 3 Bootstrap
    Choose a rom, there are several custom roms, Droid X Rom List
    Gingerbread roms will likely get better battery life, stability..
    ICS Roms are pretty stable, more features...
    No jellybean roms
    KitKat roms More features but several extra steps to install
    see one of these how to videos
    http://youtu.be/E66sxyK5jCg Tomsgt123
    http://www.youtube.com/watch?v=zs-07_y4Xqo DroidModd3rX
    No jellybean roms
    What do you think about cyannogen instead of gingerbread?
    Ive had a few friends suggests that I go with this instead of gingerbread.
    its an MB810
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    its an MB810
    Cyanogenmod type of rom for Android devices.
    Gingerbread is an android version.
    Sent from my XT907 using Tapatalk
    i have the phone rooted but I cant buy anything through google play currently
    Does anyone know where I can get a bootstrapper for free that will work??
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    [HOW TO] Install/Use Droid 2/X/3 Bootstrap
    Points: 2,987, Level: 33
    Level completed: 58%, Points required for next Level: 63
    Overall activity: 5.5%
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    Another thing to consider if your preowned X is still running slow...
    Maybe the previous owner did not wipe it. You may wish to factory reset, or, as a last resort, sbf. This is the easiest way I've found to sbf:
    Be sure to check what system version your X is running; that will determine which EZsbf image file you use. There are links that will get you to each in the above thread.
    As far as roms, there were a lot of epic developers for the X. I've posted some brief information about some of my favorite roms here:
    What are Your Favorite Custom ROMs?
    Note that I took the .621 update; so many of the older roms came from the selection of roms Goose patched a few years back.
    Flashing a rom, and the associated wiping process, will purge traces of the previous owner as well.
    Good Luck!
    Sent from my Droid X using Tapatalk 2
    sd_shadow likes this.
    OK I have rooted it, used droid recovery app from google play.
    The phone is running 2.3.4 currently, which is already gingerbread right?
    What can I put on there that will make it run better?
    Im really not sure where to proceed from here, originally I wanted CM but it says unsupported device.
    What should I do now to make this thing run better.
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Links to instructions, how to videos, and roms have been posted already.
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    2.3.4 is the first .621 update. It actually runs very well; its just not very flexible "out of the box". If its not running well: wipe or sbf.
    As Shadow indicated, the instructions and links in the above posts give you all the info you need.
    Read this too: Important Info for .621 Update! Goose really does a great job of addressing .621. You'll benefit from the perspectives of a lot of smart contributors as well.
    Also, listen to Shadow; he knows. Visit his site (Droid X Rom List above); he provides.
  1. Acting for a friend with ALS
    By Gold68 in forum New Member Introductions & Site Assistance
    Last Post: 08-28-2012, 02:42 AM
  2. Help a friend out
    By polarbehr in forum Droid X Rooted Issues
    Last Post: 06-13-2011, 10:07 AM
  3. Helpppp!!!
    By mps623 in forum Droid X Help
    Last Post: 10-03-2010, 06:26 PM
  4. Emulator helpppp
    By Yump in forum Droid X Help
    Last Post: 08-30-2010, 10:09 PM
