Need to replace my phone
This is a discussion on Need to replace my phone within the Droid X General Discussion forums, part of the Droid X Discussion category; I need to replace my Motorola Droid X2 with a similar one. It's a Motorola Droid X2 MB870 (similar to mine) that I want to ...
Thread: Need to replace my phone
    Points: 2,194, Level: 28
    Level completed: 30%, Points required for next Level: 106
    drdave's Avatar
    66513
    Aug 2013
    32
    I need to replace my Motorola Droid X2 with a similar one. It's a Motorola Droid X2 MB870 (similar to mine) that I want to buy. It does not come with Sim Card (not sure if it has a slot for one) but I don't think mine use one either. I only see a slot for a Micro SD Card.
    Can I use this phone on Page Plus?
    Thanks
    drdave's Avatar
    66513
    Aug 2013
    32
    Quote Originally Posted by drdave View Post
    Actually all the guy said is that it does not come with a Sim Card. When I open mine I don't see a Sim Card slot only a Micro SD slot. So I am assuming they don't need Sim Card. That is what confused me when he said that and why I am asking in the forums.
    Just want to know if it will work with PagePlus.
    Thanks folks
    Points: 18,701, Level: 86
    Level completed: 71%, Points required for next Level: 149
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Thanks folks
    cdma phones do not use sim cards unless they are 4G/LTE compatible, Verizon/PagePlus is cdma.
    Make sure it's a MB870 (verizon) and not MB867 (non-verizon) it's on the label under battery.
    Should work just fine with pageplus.
    drdave's Avatar
    66513
    Aug 2013
    32
    Sounds like a perfect match.
    Thanks for your help
  1. Cracked screen - replace with insurance or new phone?
    By valglbgl in forum Droid X Rescue Squad
    Last Post: 03-26-2012, 07:01 AM
  2. Anyone replace an X through Assurion in the last few? 9-14-11
    By JDW in forum Droid X General Discussion
    Last Post: 09-25-2011, 08:12 AM
  3. Help! New DX is on its way to replace troubled one!
    By MovieMan in forum Droid X Help
    Last Post: 02-12-2011, 10:16 AM
  4. Will VZW replace my phone if there is a massive soft spot on my screen?
    By hijackerjack in forum Droid X General Discussion
    Last Post: 12-02-2010, 09:19 PM
  5. First to replace?
    By n0m0n in forum Droid X General Discussion
    Last Post: 07-15-2010, 06:54 PM
