Maps on Droid X
This is a discussion on Maps on Droid X within the Droid X General Discussion forums, part of the Droid X Discussion category; I download a map for use offline and it is there for, lets say weeks, and then they need to be redownloaded...why can't I keep ...
Results 1 to 7 of 7
Thread: Maps on Droid X
    Points: 319, Level: 6
    Level completed: 38%, Points required for next Level: 31
    Overall activity: 3.5%
    rbart46's Avatar
    66608
    Sep 2013
    9
    Maps on Droid X
    I download a map for use offline and it is there for, lets say weeks, and then they need to be redownloaded...why can't I keep these...this phone is not rooted because I'm afraid of not having the phone due to disaster...so...bolster my confidence and help with maps...thanks from Robert of Cow Hill, Vermont....
    Points: 18,045, Level: 85
    Level completed: 39%, Points required for next Level: 305
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    i haven't used google maps much offline, sounds like they are expiring after a certain time like 14- 30 days.
    I would try a non google map app, there are several offline map and navigation apps
    Navfree USA: Free Satnav
    Sygic: GPS Navigation
    osmand
    skobblers
    edit:
    from http://www.thriveforums.org/forum/to...caching-5.html
    Google's solution is maddeningly close to a true offline map, which a user could store on a phone or tablet and then use without a data connection. But there are several drawbacks: the map expires in 30 days,
    rbart46's Avatar
    66608
    Sep 2013
    9
    Thank you, I have gone OsmAnd maps for now...does my droid X have a gps...I check the stand alone gps but never connect...something is missing in my method...this is fun...
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    stock 2.3.4/4.5.621?
    menu>settings>Location & security>standalone GPS services?
    could be a hardware issue, here are some threads on that.
    I fixed my GPS after 9 months not working. This is how.
    Droid X GPS Fix (for those who can't see any) - xda-developers
    GPS (and Wifi) not working? Here's the fix - Android Forums
    could be a software issue try a hard reset or flash the 621 sbf
    Hard Reset via Android Recovery-
    DX (MB810) ezSBF & Root 2.3.4/4.5.621
    or
    Using RSD Lite to flash a .SBF to restore (Stock Rom)
    rbart46's Avatar
    66608
    Sep 2013
    9
    New problem with Google Maps and OsmAnd Maps...neither will scroll along to keep up with the "you are here" marker...must move by hand and that is a distraction while driving...HELP...and thank you for being there again...
    rbart46's Avatar
    66608
    Sep 2013
    9
    got the gps working just fine...duh...turn off the airplane mode....gps works faster than my Magellon gps....
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    if you are not using cdma (verizon), you might be able to turn off radio with
    dial *#*#4636#*#*
    phone info
    turn of radio
    gps should still work
  1. Replies: 5
    Last Post: 11-30-2011, 01:34 PM
  2. Replies: 8
    Last Post: 09-03-2011, 08:06 AM
  3. Droid X navigation and google maps
    By radtech91 in forum Droid X Help
    Last Post: 07-11-2011, 10:14 AM
  4. need help using gis maps on droid x
    By steven west in forum Droid X Help
    Last Post: 05-12-2011, 01:41 PM
  5. PC Maps to Droid Maps?
    By n0m0n in forum Droid X General Discussion
    Last Post: 08-23-2010, 08:46 PM
best offline navigation app for droid x mb810
droid x2 as standalone gps
google maps offline expire
