I use the Droid X Multimedia Dock, which is on my nightstand. I have an app that controls the sounds based on a timeframe (Silent Sleep ...actually looking for a different app that still allows incoming phone calls for select people). I mainly use the dock for charging overnight and the alarm clock.
The problem I have is when receiving email (yahoo, gmail, etc.) the Droid X LED notification light blinks which is bright enough to sleeping sometimes difficult. I usually force the display to sleep because the dim setting for the dock app is not dim enough.....but, by doing that the LED will now go off when email comes in.
I'm looking to either disable the LED light automatically during a certain timeframe or manually disable it with a toggle .......and/or an app that will control the screen brightness so I can turn it down more than the default that the multimedia dock sets it to.
Anyone know of an application that can achieve the desired result? .....I'm looking for an app or toggle to either manage manually or automatically based on timeframe (free or paid....doesn't matter) ...not interested in turning phone off, placing screen face down (I'm using the multimedia dock) or using black electrical tape over the light.
Thanks,
ADK
