Looking for silicone case that can accomodate PowerMat battery door
This is a discussion on Looking for silicone case that can accomodate PowerMat battery door within the Droid X General Discussion forums, part of the Droid X Discussion category; Hi all, I picked up a PowerMat battery door for the Droid X, it is a bit thicker kind of like an extended battery door ...
Results 1 to 1 of 1
Thread: Looking for silicone case that can accomodate PowerMat battery door
    Points: 2,440, Level: 29
    Level completed: 94%, Points required for next Level: 10
    Overall activity: 5.4%
    fofopuka's Avatar
    63453
    Dec 2012
    68
    Hi all, I picked up a PowerMat battery door for the Droid X, it is a bit thicker kind of like an extended battery door and also has a plug for the micro USB.
    Does anyone know of a silicone case which is flexible enough or could be modified/trimmed to easily work with this battery door?
    The side plug area could be trimmed with an Xacto knife, I think the main requirement is that it should have space for the thicker back. Most cases I have seen for Droid X are sculpted to closely fit its unique shape of the fatter top and slim body, leaving no extra space for a larger replacement door.
    The only possibility I can think of is if one of the makers of extended battery doors would also make a case which would fit it.
    Thanks!
  1. Case that will fit with powermat door???
    By generalbegg in forum Droid X Accessories
    Last Post: 03-31-2011, 08:47 PM
  2. Hard Snap On Case vs Silicone Soft Case
    By omnicious in forum Droid X Accessories
    Last Post: 01-19-2011, 07:40 PM
  3. any negatives to leaving extended battery door off with case?
    By hemi1300 in forum Droid X Accessories
    Last Post: 11-29-2010, 10:09 PM
  4. Wanted: DX clip holster that will accomodate a silicone cover
    By harry64 in forum Droid X Accessories
    Last Post: 11-15-2010, 07:41 PM
  5. Tip for anyone using a hard or silicone case
    By Garemlin in forum Droid X Accessories
    Last Post: 07-13-2010, 09:19 PM
