Looking for earbud for Droid X2 phone
This is a discussion on Looking for earbud for Droid X2 phone within the Droid X General Discussion forums, part of the Droid X Discussion category; I searched the forums looking for a good recommended earbud. Sounds like the Vmoda might be a good choice but the post was about 4 ...
Thread: Looking for earbud for Droid X2 phone
    Points: 2,194, Level: 28
    Level completed: 30%, Points required for next Level: 106
    drdave's Avatar
    66513
    Aug 2013
    32
    I searched the forums looking for a good recommended earbud. Sounds like the Vmoda might be a good choice but the post was about 4 years old. I need decent enough quality for music as well as talk on my phone. It's a Droid X2.
    Any recommendations. If the Vmoda is a good choice which model should I get?
    Thanks
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    I don't use earbuds to talk on my phone much, but in my experience the cheapest ones aren't very good and the expensive ones aren't worth it. I'd check amazon for earbuds with 4+star reviews for something in the 10-20 range. I'd say fit is more important than anything else, though, and unfortunately you can't test that until you try them out.
    Check out my themes:
    drdave's Avatar
    66513
    Aug 2013
    32
    I agree with you. I bought some accessories on Ebay including earbuds but the thing sound so crappy I can't even talk on the phone with it. I think I will shop around locally for one for now and pretty much go by what I hear. In the past I will usually test them out by calling someone first before buying. Then I can easily test the quality as well for music listening.
    I appreciate your help and will keep Amazon in mind in the event things don't work out.
    Thanks
  1. Replies: 12
    Last Post: 03-22-2012, 12:39 AM
  2. Is the Droid X a bad phone?
    By artmanphoto in forum Droid X General Discussion
    Last Post: 02-17-2011, 10:54 PM
  3. New droid phone
    By Legendwhyte610 in forum Droid X General Discussion
    Last Post: 11-07-2010, 01:04 AM
  4. Droid X can't be used as a phone
    By FrederickMD in forum Droid X General Discussion
    Last Post: 09-27-2010, 08:56 AM
  5. All Droid.org has a Dev Phone!!!
    By drew823 in forum Droid X Hacks
    Last Post: 08-10-2010, 03:38 PM
