BH6X fit into normal door?
This is a discussion on BH6X fit into normal door? within the Droid X General Discussion forums, part of the Droid X Discussion category; Will a BH6X fit in a normal size BH5X door ...... I could order the battery (BH6X) of amazon for 10.99 but if I get ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: BH6X fit into normal door?
    Points: 913, Level: 16
    Level completed: 13%, Points required for next Level: 87
    Overall activity: 2.2%
    tbt666's Avatar
    49915
    Oct 2011
    33
    Will a BH6X fit in a normal size BH5X door ...... I could order the battery (BH6X) of amazon for 10.99 but if I get it with its door it would cost 35 or more and so would it work ok?
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    It will possibly fit but the added pressure will ruin your screen display over time. I'd recommend if you buy the extended battery that you get the door also.
    Sent from my Black Iced X
    Developer
    Developer
    Points: 12,233, Level: 72
    Level completed: 46%, Points required for next Level: 217
    Overall activity: 20.1%
    Wizard0f0s's Avatar
    29569
    Seneca, SC
    1,007
    92 times
    Quote Originally Posted by tbt666 View Post
    Unfortunately, the answer is "sometimes". Mine did NOT fit with the stock door, others have. I got the BH6X door separately for less than that on Amazon, but it has been several months ago
    The fastest way to learn is to break something. The learning comes with fixing it again.
    You can get to all of our available ROMs by heading
    over to our ChameleonOS Downloads page.
    Also make sure to flash the latest 4.2.2 gapps
    Check out our homepage at ChameleonOS.org and our forums
    Bug Tracker | Gerrit Review | GitHub
    Buy me a drink! Please don't feel obligated to donate. If you donate, please send me a PM so I can match you to the donation.
    Points: 7,196, Level: 56
    Level completed: 23%, Points required for next Level: 154
    Overall activity: 28.4%
    1,340
    78 times
    I'd go with both of these people. I've heard of the door fitting, when I got my 6X it did not fit. There have also been plenty of people who thought it fit though, and two months later had a broken screen. Personally I can't recommend it based on that track record; so I'd say just get the door. I mean you might get lucky with the 5X door, if you want to check it out first feel free. But if its tight AT ALL (you have to press to get it to slide in properly, compared to the normal slide in action it has) then you need another door.
    Points: 22,589, Level: 93
    Level completed: 24%, Points required for next Level: 761
    Overall activity: 38.8%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,635
    134 times
    just to add on what's said above... the margin is so small.. sometimes you can get away with it.. sometimes(most times actually) the door will fit... but(as i saw first hand) it will put pressure on the screen and actually cause a rainbow effect in the middle of the screen...
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 15,680, Level: 80
    Overall activity: 44.7%
    maybish's Avatar
    20852
    new jersey
    5,275
    123 times
    +1 for what nemo said. I was using the extended battery and was ggetting that rainbow effect then i took off the back cover and used it without the cover and a case on. Worked very nicely after that!
    ***May's Galaxy***
    tbt666's Avatar
    49915
    Oct 2011
    33
    Ok ... yea I ordered the door two but I was just worried that my defender otterbox wouldn't fit over the back soooooo yea
    Points: 970, Level: 16
    Level completed: 70%, Points required for next Level: 30
    Overall activity: 1.6%
    mhans311's Avatar
    52442
    Dec 2011
    145
    I did what may said. I used it without the door at all in the case. Still fit perfectly that way.
    Bionic'd from my tapatalk.
    Points: 7,721, Level: 58
    Level completed: 86%, Points required for next Level: 29
    Overall activity: 11.0%
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    2,810
    Is the rainbow effect a pixel issue? My sick little Xena has dead pixels and she has had a 6X in her with a 5X door for over 2 years. And she didn't have pixels until a month after overheating so badly in a hot car. That was before I got her from my Mum that she overheated. Xena started getting dead pixels a week after I got her
    56858
    Mar 2012
    2,810
    I decided that there will be no more 6X's for Xena. She will only be allowed to use 5X's from now on. I even said " OK Xena, no more Xtendeds for you cuz I'm not buying you another battery door. Because your battery door has a Hyacinth Macaw tattooed on your back end and its the only way I can tell if you're Xena or X. And you need something to make the male DX's think you're pretty", I always talk to my Droids cuz I love them so much. Its part of my Autism
  1. BH6X OEM extended battery owners please read
    By Stuckinabox in forum Droid X General Discussion
    Last Post: 02-11-2013, 07:44 PM
  2. BH6X Extended Battery
    By Kench in forum Droid X Help
    Last Post: 02-12-2012, 11:25 PM
  3. Another extended battery question... BH6X, SNN5880A
    By MotoDroidX31 in forum Droid X Help
    Last Post: 01-09-2012, 04:03 PM
  4. BH6X battery posibilities?
    By MrX in forum Gingerbread Roms
    Last Post: 09-22-2011, 09:09 PM
  5. Looking for an inexpensive BH6X
    By fsand in forum Droid X Accessories
    Last Post: 07-15-2011, 08:40 PM
BH5x vs BH6x
bh5x bh6x size
bh5x vs bh6x size
bh6x
bh6x vs bh5x
difference between bh5x and bh6x
difference between bh5x and bh6x battery
droid x battery bh5x vs bh6x
motorola bh5x vs bh6x
what is the difference between bh5x and bh6x
