My GPS has not worked in a week. It won't even find a signal or one satalite. I have tries the tape on the back cover method and have GPS Status, Bearing, and another GPS app and none find the signal. Any ideas?
This is a discussion on Gps within the Droid X General Discussion forums, part of the Droid X Discussion category; My GPS has not worked in a week. It won't even find a signal or one satalite. I have tries the tape on the back ...
What are you running currently, a ROM or stock?
Need more help? Click above ^
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
.621 Root
Android Dictionary
Have you tried wiping cache in recovery?
on the move..
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
.621 Root
Android Dictionary
How would I do that? I can go into GPS Status and reset all cached GPS data. Did that many times and still doesnt work.
Power phone off. Now hold home first, and then power past the red M to a screen with Andy the Android and a triangle with an exclamation point in it. At that screen press both volume keys simultaneously. That should open a menu. Scroll to wipe cache. Use volume to navigate and power to execute. Then reboot.
Sent from my Black Iced X
You open to root it? May be able to replace some configuration files to make it work.
Tapped from my jelly-beaned d2vzw
Behind the battery door is a little golden like tab. Is it damaged?
Fart Blood
68 88 32 45 32 79 67 32 49 46 50 32 103 104 122 32 71 66 32 118 46 48 53 13 10
