I'm very new to rooting/custom roms on the droid x and could use some help
This is a discussion on I'm very new to rooting/custom roms on the droid x and could use some help within the Droid X General Discussion forums, part of the Droid X Discussion category; Button savior is a big one. It puts the menu, home, back, search, volume, camera, and power buttons right on screen so your physical buttons ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: I'm very new to rooting/custom roms on the droid x and could use some help
    Points: 18,305, Level: 85
    Level completed: 91%, Points required for next Level: 45
    Overall activity: 95.4%
    6,302
    139 times
    Button savior is a big one. It puts the menu, home, back, search, volume, camera, and power buttons right on screen so your physical buttons don't get worn out. Titanium BackUp is another big one. Back up all your user and system data along with apps in case of some unforeseen problem in the future. Screen Grabber is nice because if gives you the option of taking screen shots in .png or .jpg formats and from within apps (which stock screenshot app on some roms does not allow.)
    Points: 1,816, Level: 25
    stedmakr's Avatar
    13447
    8
    My question is about how to reinstall apps after wiping the phone. Is there anything that can be done during the flashing process or afterwards that can automate the installation of all apps that are part of my home screens? I am concerned that I will have to reinstall the apps one at a time. Thanx
    6,302
    139 times
    If you use titanium backup (pro) you can batch restore all your apps after you wipe.
    Sent from my X2 using DXF
    stedmakr's Avatar
    13447
    8
    Thanks - two points of clarification. I have titanium pro and the terminology used is "backup all". Is that the same as batch? Also there are several restore all options. Do I restore apps, apps with data, or all system data?
    Second question is do I restore after I have flashed then rebooted or at an earlier point in the process.
    Thank you so much
    6,302
    139 times
    If you click on the backup tab in titanium and then press menu there should be a batch option. Then it gives you options. User apps is what you would want to back up. (This will include user data.) Never restore system data on different set ups.
    And you restore them after you flash and reboot. Once the ROM is up and running.
    Points: 106, Level: 2
    Level completed: 12%, Points required for next Level: 44
    Overall activity: 1.9%
    jt11's Avatar
    63044
    Nov 2012
    8
    I am new to rooting and have rooted my droidx,2.3.4, system 4.5.621.
    Which custom ROM do I need?
    How do I install it.
    Thanks a lot.
  8. #17
    Points: 3,147, Level: 34
    Level completed: 65%, Points required for next Level: 53
    Overall activity: 2.7%
    newmanx4's Avatar
    34469
    703
    27 times
    Depends on what you want out of a ROM. Most Gingerbread ROMs have everything working. Ice Cream Sandwich ROMs have a few things broken, Netflix(all ICS ROMs) and video camera(hit or miss) being the big two.
    Sent from my Black Iced X
  9. #18
    Points: 792, Level: 14
    Level completed: 92%, Points required for next Level: 8
    Overall activity: 2.6%
    phabeon's Avatar
    60293
    Jul 2012
    58
    newmanx4 - i would like better battery life, working camera, stability and SPEED.. already tried MIUI, what next?
    jt11 - try Wizards MIUI, see 1st post here.. MIUI the sticky.. you will love it!
    oNe
  10. #19
    Themer
    Points: 10,971, Level: 69
    Level completed: 31%, Points required for next Level: 279
    Overall activity: 18.1%
    jeems's Avatar
    40702
    3,747
    73 times
    Quote Originally Posted by phabeon View Post
    oNe
    try VXL (vortex liberated). It is all of those things you seek.
    Check out my themes:
  11. #20
    Points: 7,930, Level: 59
    Level completed: 90%, Points required for next Level: 20
    Overall activity: 15.7%
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    2,852
    Quote Originally Posted by jeems View Post
    Is that ICS or Gingerbread?
  1. Rooting and custom ROMs.
    By thefoureye in forum Droid X Help
    Last Post: 11-15-2011, 09:36 AM
  2. droid x to cricket with custom roms and flash help!!!
    By z_newb in forum Droid X Rooted Issues
    Last Post: 04-22-2011, 12:49 AM
  3. Putting Custom Roms on Droid X
    By DJJazzyJim2001 in forum Hacking Help
    Last Post: 11-15-2010, 11:29 AM
  4. Custom ROMS (Themes) for Droid X
    By antthedrag in forum Droid X Hacks
    Last Post: 07-23-2010, 11:44 AM
  5. Droid X Bootloader Locked, Custom ROMs Unlikely
    By wuyanks in forum Droid X News
    Last Post: 07-12-2010, 10:03 AM
Best Custom Rom for droid x
droid x 4.5.621 custom rom
droid x custom rom install
droid x install rom after root
droid x on 621 does that lock
how to flash a rom on droid x
how to root my droit x using button savior
latest custom rom for droid x
liberty rom with magic md5 droid x
zip root droidx 2.3.4
