Help with Droid X
This is a discussion on Help with Droid X within the Droid X General Discussion forums, part of the Droid X Discussion category; Can a Verizon Droid X be put on a prepaid card like Net 10 ? If so, how do I go about doin it?...
Thread: Help with Droid X
    Help with Droid X
    Points: 7,721, Level: 58
    Level completed: 86%, Points required for next Level: 29
    Overall activity: 11.0%
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    2,810
    I'm not sure, but I think it requires root access
    Points: 22,590, Level: 93
    Level completed: 24%, Points required for next Level: 760
    Overall activity: 38.8%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,635
    134 times
    i'm not sure... but you'd have to figure out if they used cdma towers... but my guess is probably gsm towers... is that's the case... no.. but if they use cdma towers... you might be might be able to... although i'm not too up on the process that would require
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 15,964, Level: 81
    Level completed: 23%, Points required for next Level: 386
    Overall activity: 76.4%
    BHuber09's Avatar
    34670
    Atlantis
    5,542
    136 times
    1. Wouldn't require root access...
    2. As nemo said. If they use cdma towers then you can just flash the service over however its up to them on how they run their service. That's just what I would think. So it all depends on the towers and if they are right I think its possible
    FreeMyMoto!!!
    If you need help PM me!!!
