How to uninstall/revert updates on X
This is a discussion on How to uninstall/revert updates on X within the Droid X General Discussion forums, part of the Droid X Discussion category; Scrabble for Android just got an update that I installed. Now the app won't run because it says my screen resolution isn't supported. The phone ...
Results 1 to 1 of 1
Thread: How to uninstall/revert updates on X
    Points: 1,030, Level: 17
    Level completed: 30%, Points required for next Level: 70
    Overall activity: 3.2%
    cooksta3276's Avatar
    54609
    Jan 2012
    52
    Scrabble for Android just got an update that I installed. Now the app won't run because it says my screen resolution isn't supported. The phone isn't even that old, just under qHD resolution. I'd rather just undo the update, which I don't think you can do in the Play Store. Any ideas??? Running Liquid ICS 4.0.4.
  1. If I were to flash a ROM, but wanted to revert back, would I have to sbf?
    By DroidXSkywalker in forum Gingerbread Development and Hacking
    Last Post: 11-08-2011, 09:59 PM
  2. Revert back to Old versio
    By Tosin123 in forum Droid X Help
    Last Post: 09-29-2011, 10:29 AM
  3. Possible to revert back to 2.2.1 after installing 2.3?
    By silverphoenix98 in forum Droid X Stock Issues
    Last Post: 05-24-2011, 12:27 AM
  4. Completely revert to stock help.
    By nolanrupp in forum Droid X Help
    Last Post: 03-31-2011, 06:17 PM
  5. Replies: 1
    Last Post: 12-09-2010, 09:18 AM
android rollback app update
how to revert droid x
how to undo update on htc 1 x
how to undo update on htc one x
how to undo update on thrive
htc one x how to undo update
htc one x undo update
revert android update
scrabble android resolution not supported
what is the screen resolution for scrabble android
