Baseband update to 15 possible with Gingerbread?
This is a discussion on Baseband update to 15 possible with Gingerbread? within the Droid X General Discussion forums, part of the Droid X Discussion category; I am running Milestone X 4.5.604 Gingerbread ( (1KDStaz_MX_4.5.604.iso)) Is there anyway to get to the baseband 15 with Gingerbread? I have tried downgrading to ...
Results 1 to 10 of 10
Thread: Baseband update to 15 possible with Gingerbread?
    Points: 71, Level: 1
    Level completed: 43%, Points required for next Level: 29
    Overall activity: 1.3%
    haas's Avatar
    59695
    Jun 2012
    7
    I am running Milestone X 4.5.604 Gingerbread ((1KDStaz_MX_4.5.604.iso))
    Is there anyway to get to the baseband 15 with Gingerbread? I have tried downgrading to Froyo with no luck. My phone always boots to a bootloader 30.04 error A5 etc. etc. no matter what I use whether RSD Lite or the Linux options.
    I had a much larger thread typed and submitted it but that seems to have been lost?
    Thanks!
    Points: 16,380, Level: 82
    Level completed: 6%, Points required for next Level: 470
    Overall activity: 77.0%
    BHuber09's Avatar
    34670
    Atlantis
    5,704
    140 times
    Quote Originally Posted by haas View Post
    Thanks!
    Well if you are on 604 then you must have been on 621. Which has the .15p radio in it.
    Or you could sbf (with rsd) to 621. Then use the Linux method to go to 604 and root then flash the 621 kernel and be rooted on 621
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    haas's Avatar
    59695
    Jun 2012
    7
    This phone never got the 621 OTA. The only way this phone was on 621 was after I had installed the milestone I installed the following ROM which did not include the radio update.
    4.5.621 Stock Rooted (621_Stock_Rooted_kY-Signed.zip)
    MD5: 093DF62735691A9D1C01A5549B3F9D59
    *** Notes ***
    - Completely Stock Rooted 4.5.621
    - Superuser 3.0.7 w/ su-bin 3.0.3.2
    - OTA updates disabled via following method: Added .bak extension to BlurUpdater_VZW and Upgrader APK / ODEX files
    So does your instructions for SBF to 621 still apply? Do you have a good link for SBF 621? I would rather use the Linux boot if that is an option?
    haas's Avatar
    59695
    Jun 2012
    7
    I just found this so am I SOL? Or does this include the 15 radio update?
    *****Do not use the 4.5.621 SBF file unless you took the OTA update, you won't be able to use any other SBF after updating or flashing to .621*****
    Android 2.3.4 System Version 4.5.621 (1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf.zip)
    MD5 (1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf.zip) = 06bbf7ee86c0ed64654e14bcb84c4aed
    BHuber09's Avatar
    34670
    Atlantis
    5,704
    140 times
    Okay well with you being on 604 your gonna have to go to 621 to get it. And here's where I get all my sbf files
    https://sites.google.com/site/1kdsdroidx/
    Just download 621 and use rsd light to sbf.
    But if you go to 621 you will be suck on 621 and 604. There won't be any going back to 605 602 or 596.
    But once you get on 621 you need to use Linux method to go to 604 then root and then flash the 621 kernel and you'll be good to go.
    FreeMyMoto!!!
    FreeMyMoto!!!
    Points: 7,321, Level: 56
    Level completed: 86%, Points required for next Level: 29
    Overall activity: 24.2%
    1,341
    78 times
    Quote Originally Posted by BHuber09 View Post
    FreeMyMoto!!!
    He's already stuck as he flashed ky's .621 AIO. He'll have to RSD Lite to .621 to update the radio. TBH he was probably stuck after doing the .604 SBF anyways.
    Sent from my secret shadow build...
    haas's Avatar
    59695
    Jun 2012
    7
    Ok, So I did rsd lite sbf to .621 which does include the radio update. That is the good news! Now according to how I am reading this I am going to have to go back to Milestone X and then root and then run the following update again?
    *** Notes ***
    BHuber09's Avatar
    34670
    Atlantis
    5,704
    140 times
    You are correct.
    FreeMyMoto!!!
    FreeMyMoto!!!
    haas's Avatar
    59695
    Jun 2012
    7
    Ok, I did exactly what I listed above and it worked like a CHARM!
    Telling me to SBF to .621 is exactly the info I needed to get this ship back in the water. Now I am at Radio 15 and 2.3.4 .621 rooted and smiling. THANK YOU SO MUCH!
    BHuber09's Avatar
    34670
    Atlantis
    5,704
    140 times
    Awesome man I'm glad I could have helped.
    FreeMyMoto!!!
    FreeMyMoto!!!
  1. help with baseband update.
    By roryt777 in forum Droid X Help
    Last Post: 12-04-2011, 08:43 PM
  2. DXC - Baseband Update .13P
    By droidxchat in forum Droid X Hacks
    Last Post: 09-06-2011, 12:16 PM
  3. Help me Not Screw Up Baseband Update
    By Cigator in forum Droid X Help
    Last Post: 08-28-2011, 04:00 PM
  4. DXC - Baseband Update .13P
    By droidxchat in forum MIUI
    Last Post: 08-16-2011, 09:21 PM
  5. baseband version update
    By zoe in forum Gingerbread Development and Hacking
    Last Post: 05-06-2011, 03:29 AM
.621 baseband signature file
621 stock rooted ky-signed.zip
can i flash .15p basband on miui droid x
droid x radio 13p to 15p on 621 rooted
gingerbread baseband upgrade
milestone baseband update
milestone x 4.5.604 baseband
miui droid x 15p
tablet 2.3.4 signed zip
wrong baseband radio after rooting droid x
