Can Droid X running 4.5.621 be flashed to a custom ROM?
This is a discussion on Can Droid X running 4.5.621 be flashed to a custom ROM? within the Droid X General Discussion forums, part of the Droid X Discussion category; what Ireally need is email app that works w exchange (outlook.com) and can show download pics in email itself (like in cm10-11) n not to ...
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Like Tree5Likes
Thread: Can Droid X running 4.5.621 be flashed to a custom ROM?
  1. #41
    Points: 2,147, Level: 27
    Level completed: 98%, Points required for next Level: 3
    Overall activity: 22.0%
    office399's Avatar
    52365
    Dec 2011
    23
    pics in email itself (like in cm10-11) n not to be separately clicked in email (like in apex -GB)
    also now that im on cm11- hwo can I go to CWM to flash VXLR..or liq ics.
  3. #42
    Points: 18,329, Level: 85
    Level completed: 96%, Points required for next Level: 21
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    Last time I tried vxlr installed twrp, but that was a few months ago, a couple of twrp updates ago
    Best to flash sbf again, or at least be prepared, if vxlr install fails
    Charge battery before trying.
    Latest liquid ICS includes bootmenu so that may install in twrp also, but 2.0 did not
  4. #43
    office399's Avatar
    52365
    Dec 2011
    23
    thx. so for liq ics- i go to twrp- wipe usual and then install rom? same steps for vxlr. in case they fail, I shd prep to do ur sbf steps?
  5. #44
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    Yes vxlr should install in twrp, liquid may...
    Yes wipe first
    Could place both ROMs on SD card
    Try liquid, if install or boot fails, and of you can still get into twrp, try vxlr
    If not sbf
  6. #45
    Points: 723, Level: 14
    Level completed: 23%, Points required for next Level: 77
    Oggie7797's Avatar
    67870
    Jan 2014
    7
    I never did use vxlr haha if you want a stable and good GB based ROM @palmbeach05 over on xda built cm7 from official source and ported it for .621 contact him. It works great I used it while back. He doesn't have a thread for it it was more of a private build. The one included on @sd_shadow doc is outdated, last I checked.
    Tap'd from my Bionic
  7. #46
    Oggie7797's Avatar
    67870
    Jan 2014
    7
    Flash cm7 bootmenu with it by wizard0f0 and it runs great.
  8. #47
    office399's Avatar
    52365
    Dec 2011
    23
    Yes wipe first
    If not sbf Sent from my DROIDX using Tapatalk
    Was trying Liq. ICS per ur directions and wanted to poll u on the WIFI issue. My wifi radio reception is pretty bad. Other 2 phones same location get 3-4 solid levels and this Droid X running Liq. ICS is barely at 1. Similar stuff noticed on just after SBFing it??
    What's going on...this cant really go on- any suggestions to restore Wifi to normal. I remeber prior to the SBF- on 604 or 602 kernel, used to get very good reception!! Pls. help with what I can do.
  9. #48
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    You were able to flash with RSD Lite, or you used the ezSBF iso?
  10. #49
    office399's Avatar
    52365
    Dec 2011
    23
    rsd lite and it went ok once I unzipped and used the unboxed sbf
  11. #50
    office399's Avatar
    52365
    Dec 2011
    23
    also.. does anyone have a recommendation for a good used phone (less than 1.5 yr old, under $200) can run a new rom well and be on pageplus (ex Verizon postpaid).
  1. Droid X flashed to Cricket
    By scootsmit2007 in forum Droid X Help
    Last Post: 11-05-2011, 09:04 PM
  2. Updating FLASHED droid x to 2.2 question ?
    By killajatt510 in forum Droid X Help
    Last Post: 09-30-2011, 11:12 AM
  3. Replies: 832
    Last Post: 04-24-2011, 08:14 PM
  4. Replies: 4
    Last Post: 03-31-2011, 11:49 PM
  5. Updating a flashed Droid X?
    By russader in forum Droid X General Discussion
    Last Post: 01-13-2011, 08:54 PM
droid x .621 roms
droid x 4.5.621 roms
droid x 621 rom
droid x 621 roms
droid x custom rom
droid x rom 4.5.621
flash droid x .621
liberty rom droid x 621
motorola droid x custom rom
roms for droid x .621
