Can Droid X running 4.5.621 be flashed to a custom ROM?
This is a discussion on Can Droid X running 4.5.621 be flashed to a custom ROM? within the Droid X General Discussion forums, part of the Droid X Discussion category; Specially if u can suggest something specific to thsi 621/604 sbf- a rom that wud have similar speed & battery to VXLR 2.2.0 which can ...
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
Like Tree5Likes
Thread: Can Droid X running 4.5.621 be flashed to a custom ROM?
    Points: 2,147, Level: 27
    Level completed: 98%, Points required for next Level: 3
    Overall activity: 22.0%
    office399's Avatar
    52365
    Dec 2011
    23
    Specially if u can suggest something specific to thsi 621/604 sbf- a rom that wud have similar speed & battery to VXLR 2.2.0 which can have full working wifi n GPS. Also if I need to do some specific flash- pls. suggest. thanks a bunch.
    office399's Avatar
    52365
    Dec 2011
    23
    awesome timing! ok. How do I do " full factory wipe" before flash full 621 sbf with RSD Lite - And u dont want me to use 1KDStaz_MX_4.5.604 ? Also how to rewipe?
    Points: 18,472, Level: 86
    Level completed: 25%, Points required for next Level: 378
    Overall activity: 56.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    1KDStaz_MX_4.5.604 does not flash radio (cdma, wifi, fm, bluetooth...) so if any of them is not working, ezSBF(1KDStaz) does not fix
    Links in my list sd_shadow's [Collection] of Links For: Droid X but here it is
    Hard Reset via Android Recovery-
    office399's Avatar
    52365
    Dec 2011
    23
    this is where my 20 hrs of forum trolling was outdid by ur experience! thanks.
    just to reconfirm u want me to (per ur links)
    1. do hard reset
    2. flash 621 sbf with RSD Lite - then install Bootstrap 2 modified (Droid2Bootstrap621MOD.apk)
    3. do hard reset again (can I not use the CWM- data wipe/factoery reset)
    4. install - OA-VXLR_2.2.0_Installer_Spz0-3b1904eb9234b4e74e7ded9503f23e05.zip (this is only link I managed)
    5. enjoy wifi on DX finally back n then, applaud u!
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by office399 View Post
    1. do hard reset
    1. Yes
    2. Yes, Note: once 621 is flash no older sbfs will work, this was only an issue when 621 was not rootable
    verify 621's md5 checksum before flashing see https://sites.google.com/site/sdshad...hash-checksums
    3. Yes unless Phone bootloops after flashing SBF, Then you need to wipe in Stock Recovery
    4. Yes, If that is m.ksy's Mega link, I also just uploaded copy to DevHost but Mega is better as it checks md5 as part of the encryption process
    office399's Avatar
    52365
    Dec 2011
    23
    1. Yes
    I wanted this to be the congrats & thanks note but when I went to step of flashing file thru RSD lite- it keeps giving me the error
    " Error!!!!! Failed to create Please check if the file path is too long to create or if there is enough free disk space."
    than I went thru trouble shootiing as in- If you get "Failed Flashing process. (0x7100)" in RSD Lite - Android Forums
    but still same error...there is no flashing error log but SWDL shows this below. PLS. HELP !!!
    10/09/14 15:58:13 00003610 Phone.cpp 1659 0 ERROR GetPhoneID failed: ERROR.
    10/09/14 15:58:13 00003610 Phone.cpp 518 0 ERROR Generic failure when sending command.
    10/09/14 15:58:13 00003610 Phone.cpp 1754 0 ERROR GetTechnology failed: ERROR.
    10/09/14 15:58:13 00003610 Phone.cpp 1823 0 ERROR GetSoftwareVersion failed: SendTC failed: ERROR.
    10/09/14 15:58:13 00003610 Phone.cpp 1981 0 ERROR GetSoftwareFlexVersion failed: ReadSeemElement failed: ERROR.
    10/09/14 15:58:13 00003610 Phone.cpp 1870 0 ERROR GetDRMVersion failed: SendTC failed: ERROR.
    10/09/14 16:03:16 00003610 Phone.cpp 518 0 ERROR Generic failure when sending command.
    10/09/14 16:03:16 00003610 Phone.cpp 1659 0 ERROR GetPhoneID failed: ERROR.
    10/09/14 16:03:16 00003610 Phone.cpp 1754 0 ERROR GetTechnology failed: ERROR.
    10/09/14 16:03:16 00003610 Phone.cpp 1823 0 ERROR GetSoftwareVersion failed: SendTC failed: ERROR.
    10/09/14 16:03:16 00003610 Phone.cpp 1981 0 ERROR GetSoftwareFlexVersion failed: ReadSeemElement failed: ERROR.
    10/09/14 16:03:16 00003610 Phone.cpp 1870 0 ERROR GetDRMVersion failed: SendTC failed: ERROR.
  8. #17
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    What is full file name of sbf?
    Sent from my XT894 using Tapatalk
  9. #18
    office399's Avatar
    52365
    Dec 2011
    23
    1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf - Also tried renaming it as suggested in those work arounds
    wasnt sure u'll be so quick or wunt have stepped out..Im, here now to execute whatever u need me to
    RSDLite5.7.exe n Motorola_End_User_Driver_Installation_5.9.0_64bit were used.
  10. #19
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Looks like the error is from the sbf is buried too far in folders
    Try moving it to desktop, run rsd lite as admin
  11. #20
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Also which windows version? 7, 8...
  1. Droid X flashed to Cricket
    By scootsmit2007 in forum Droid X Help
    Last Post: 11-05-2011, 10:04 PM
  2. Updating FLASHED droid x to 2.2 question ?
    By killajatt510 in forum Droid X Help
    Last Post: 09-30-2011, 12:12 PM
  3. Replies: 832
    Last Post: 04-24-2011, 09:14 PM
  4. Replies: 4
    Last Post: 04-01-2011, 12:49 AM
  5. Updating a flashed Droid X?
    By russader in forum Droid X General Discussion
    Last Post: 01-13-2011, 09:54 PM
droid x .621 roms
droid x 4.5.621 roms
droid x 621 rom
droid x 621 roms
droid x custom rom
droid x rom 4.5.621
flash droid x .621
liberty rom droid x 621
motorola droid x custom rom
roms for droid x .621
