Important Info for .621 Update!
This is a discussion on Important Info for .621 Update! within the Droid X General Discussion forums, part of the Droid X Discussion category; its been awhile since ive messed with my x whats better for .621 the x recovery or the droid2 recovery...
Page 6 of 11 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 105
Like Tree16Likes
Thread: Important Info for .621 Update!
  1. #51
    Points: 11,004, Level: 69
    Level completed: 39%, Points required for next Level: 246
    Overall activity: 4.7%
    shawn's Avatar
    27626
    eugene, oregon
    1,158
    57 times
    DX2 eclipse with some tweaks
  3. #52
    Points: 1,152, Level: 18
    Overall activity: 3.3%
    Aptiva's Avatar
    57621
    91
    Quote Originally Posted by shawn View Post
    As far as bootstrap? DX one won't work on GB flavors. D2 Bootstrap will work on GB. As far as updating in Rom Manager, I usually use the Droid X 2nd Init personally usually without fail.
  4. #53
    Points: 2,680, Level: 31
    Level completed: 54%, Points required for next Level: 70
    spex921's Avatar
    31385
    Monterey Bay, California
    85
    I'm not a staffer, but I was curious about the new method, and wanted to see it work. And it is easy and it does work!
    On Monday I took the .iso and used unetbootin to create a usb boot drive. I sbf'd with RSD Lite, activated, then booted my computer with my usb stick and followed the instructions. It is pretty straight forward and it worked perfectly. I loaded Droid2Recovery (to answer the question about which recovery), and flashed the .621 version of VXL 1.0 and I'm not looking back...
    Goose306 likes this.
  5. #54
    Aptiva's Avatar
    57621
    91
    I just used it myself and it went flawlessly. Exactly as it is supposed to work. I'm going to do a few more runs on it to see if I can narrow down the CWM issues people are having. I managed to get D2 Bootstrap to install CWM and updated it through RM to the DX Recovery (not 2nd init) and CWM booted fine. I did do the recommended NFS nuke with Rom Toolbox's built in Root Browser. Doing another SBF as I type this so I can try it without deleting NFS from preinstall to see if it truly is an issue, but it really was just as fast as the normal 1kds SBF method with rooting scripts built in. It does flash a new preinstall folder when you use this root method, but after you root if you have issues with CWM, just use a root browser to nuke the NFS apk in /preinstall and CWM does in fact work. I haven't flashed any roms yet, but I just set off in testing this, so when I flash back to CM9, I will post more findings.
  6. #55
    Points: 7,192, Level: 56
    Overall activity: 28.2%
    1,340
    78 times
    Quote Originally Posted by Aptiva View Post
    So is it faster then than the 1KDS SBF? I know the download is obviously smaller, I would assume faster as well as its flashing less CG (code groups)?
    I would try seeing if you can go from a bone-fresh .621 base; flash that SBF/root package, install D2 Bootstrap, and then update via CWM to Droid X (2nd-init) that would be the most common route and path of least resistance. (Without nuking NFS if possible)
    Oh, and thanks for testing as well!
  7. #56
    Aptiva's Avatar
    57621
    91
    That's what I'm doing right now as a matter of fact... Yes it's faster, but less automation. No biggie imo since it's so far easier than the MX method.
    EDIT:
    CWM booted no problems without nuking nfs from preinstall. Using both d2 bootstrap and rm to boot to recovery. I used dx 2nd init cwm.
    EDIT 2:
    I did this 3 different ways as far as mediums go. I used the standard burn to CD method, USB thumb drive(more SD Card/Reader but process and function is the same), and using VMWare Player in Windows. All 3 ways went flawlessly. Started each time with a fresh SBF to .621, rooted, and flashed CWM via d2 bootstrap and rom manager. Hasn't failed once. Haven't stripped NFS out once since the first time. I completed the process 6 times total for testing. Will make the video this afternoon if I find time.
  8. #57
    shawn's Avatar
    27626
    eugene, oregon
    1,158
    57 times
    I was looking around the interwebz for more info on my X and researching whether I should finally take the .621 and I found this on Rootz... Apparently a root method similar to one being used on the D2, D2G, and R2D2 is also working for the DX and DX2. Luckily it simplifies the process of rooting the .621 as you no longer have to do the Milestone X sbf. Worth taking a look at if you're on the .621
    [Root] Droid X root method for 2.3.4/ 4.5.621 (does not require Milestone SBF) - Droid X - RootzWiki
    Just tried this method works great no issues making and restoring backups or flashing zips in recovery
    Sent from my Galaxy Nexus using Xparent Blue Tapatalk 2
  9. #58
    Aptiva's Avatar
    57621
    91
    So I never did come across what the cause of the other people's problems with CWM. I've done this 10 times over the last 2 days without any issues.
    I did flash CM9 as well as my usual hijacked boot menu, gapps, and my own custom built zip for ringtones and it went without a hitch. I only have the 1 DX atm (hopefully will have a 2nd not long from now) so if it's a phone to phone issue, I haven't come across it with my current one.
    Side note:
    CM9 is much more responsive and works 100x better on the .621 kernel in my experience so far, but that doesn't mean you should just take the OTA if you haven't. Make sure to do the research before you do it and make a well informed decision like I did. I was on .605 until this root method was found and honestly I think it was the only thing that was truly stopping me because I'm not a fan of flashing software for other phones on one they're not designed for, not that the Milestone X SBF method wasn't tried and true.
  10. #59
    Moderator
    Points: 4,819, Level: 44
    Level completed: 35%, Points required for next Level: 131
    Overall activity: 50.7%
    sd_shadow's Avatar
    56013
    South Dakota
    645
    50 times
    I've posted the new root method here on this site, with detailed instructions
  11. #60
    1,340
    78 times
    Thanks bud. I've been meaning to integrate that into the OP here but was waiting on a DX tester then when we got one its been about a week so haven't had much time. I'll see about pushing that update through
    Sent from my jellybeaned AOKP GSIII
  1. Important question.. Need help
    By sixxstarz in forum MIUI
    Last Post: 12-08-2011, 02:58 PM
  2. How important is a screen cover?? Do I need one?
    By cumberlandgray in forum Droid X Accessories
    Last Post: 10-28-2010, 07:38 AM
  3. Important Question (ROM)...Noob here
    By gokor89 in forum Droid X ROMs
    Last Post: 10-13-2010, 05:04 AM
  4. 2 Important APPS I think EVERYONE should install.
    By NY_ROCKER in forum Droid X Apps
    Last Post: 09-07-2010, 01:46 PM
1kds live cd
droid x 621 update
droid x update
important info for .621 update
this device is currently not authorized to access dial-up networking services, please contact your wireless service prov
verizon error on phone: your phone is not authorized currently to be used as a dial up connection
your phone is not currently set up to be used as a modem or mobile hotspot
your phone is not currently set up to be used as a modem or mobile hotspot. to see if these services are available, clic
zergrush v4
zergrush v4 root method droid x
