Important Info for .621 Update!
This is a discussion on Important Info for .621 Update! within the Droid X General Discussion forums, part of the Droid X Discussion category; Originally Posted by Aptiva Correct. Linux sbf flash skips the bp pass through mode and does not flash the radio. Personally that's why I suggested ...
Page 11 of 11 FirstFirst ... 91011
Results 101 to 105 of 105
Like Tree16Likes
Thread: Important Info for .621 Update!
  1. #101
    Quote Originally Posted by Aptiva View Post
    Correct. Linux sbf flash skips the bp pass through mode and does not flash the radio. Personally that's why I suggested using the 2 step method. I didn't think about the Linux sbf method skipping that part or I would have mentioned it. iirc you can't flash 15p without being on the froyo kernel which is out of the question since reversion was stripped from us with .621. Use rsd lite to sbf the radio
    Sent from my CM10.1 Cricket SGS3
    OK, guess I will pursue that method then.
    Is there anything else that I didn't get with the Linux SBF?
  3. #102
    Points: 4,713, Level: 43
    Overall activity: 1.6%
    newmanx4's Avatar
    34469
    703
    29 times
    Nope. Just the 15p radio.
    Sent from my RAZR MAXX HD using Tapatalk 2
  4. #103
    OK, got my radio updated.
    One curious thing though, after it installed the sbf, it rebooted my phone, but RDS Lite didn't recognize that my phone had booted up. I was able to call *228 and activate my phone and make calls on it.
    Is there anything to worry about? The process seems to have been successful to me. But I'm a touch worred since RSDLite didnt recognize that the phone had rebooted.
    One more thing, should I do a factory reset? Like I said earlier, everything is working.
    Overall this process was pretty easy to do. Thanks to everyone for giving me guidance.
  5. #104
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    Don't worry about it. Glad you got everything going!
    Check out my themes:
  6. #105
    Points: 18,669, Level: 86
    Level completed: 64%, Points required for next Level: 181
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    rsd lite sometimes does not recognize, that the phone has finished booting, nothing to worry about
    phone should be in bootloader mode, when using rsd lite, and may take a moment for windows to find drivers
    I recommend wiping data/factory reset if changing system versions, but if it's working fine, it's your choice
  1. Important question.. Need help
    By sixxstarz in forum MIUI
    Last Post: 12-08-2011, 03:58 PM
  2. How important is a screen cover?? Do I need one?
    By cumberlandgray in forum Droid X Accessories
    Last Post: 10-28-2010, 08:38 AM
  3. Important Question (ROM)...Noob here
    By gokor89 in forum Droid X ROMs
    Last Post: 10-13-2010, 06:04 AM
  4. 2 Important APPS I think EVERYONE should install.
    By NY_ROCKER in forum Droid X Apps
    Last Post: 09-07-2010, 02:46 PM
droid x 621 update
droid x update
important info for .621 update
this device is currently not authorized to access dial-up networking services
this device is currently not authorized to access dial-up networking services, please contact your wireless service prov
this device is currently not authorized to access dial-up networking services,please contact your wireless service provi
your phone is not currently set up to be used as a modem or mobile hotspot
your phone is not currently set up to be used as a modem or mobile hotspot. to see if these services are available, clic
zergrush v4
zergrush v4 root method droid x
