Charging with a 24 volt cigarette lighter.
This is a discussion on Charging with a 24 volt cigarette lighter. within the Droid X General Discussion forums, part of the Droid X Discussion category; Will this hurt my phone or battery? Always been curious. I work in a Liehberr Crane which is shipped from Germany. Hence the 24v outlet. ...
Results 1 to 10 of 10
Thread: Charging with a 24 volt cigarette lighter.
    Points: 2,255, Level: 28
    Level completed: 70%, Points required for next Level: 45
    Rosie685's Avatar
    24697
    91
    Will this hurt my phone or battery? Always been curious. I work in a Liehberr Crane which is shipped from Germany. Hence the 24v outlet. However our maintenance dept has to install power converters in the cranes to hook up the motorola radios. For a long time now I just rigged up my own car charger and wires and tapped into that to charge my phone but the other day I plugged it into the 24v outlet and it looked to be charging. I didn't leave it charging just in case. When it is on the charger in the crane it stays around 4 volts on my battery app whatever that means
    Rosie685's Avatar
    24697
    91
    74 views and know one knows? :-/
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    Are you sure the lighter is 24 volts? I have a work truck that has a 24 volt system, but the lighter and other power ports are just 12 volts.
    Rosie685's Avatar
    24697
    91
    Yea i had a maintenance guy hook his meter up to it and it read 23.8
    newmanx4's Avatar
    34469
    703
    27 times
    I don't know if that would cause damage or not.
    Themer
    Points: 10,920, Level: 69
    Level completed: 18%, Points required for next Level: 330
    Overall activity: 29.6%
    jeems's Avatar
    40702
    3,747
    73 times
    I can't answer your question directly but I can give you some information. Note, you do not want to mix voltages when it comes to batteries. That said, the charger has internals that convert the 12V down to a safe level for our batteries, my battery says 3.7V, so it probably sends 4-5 volts for charging purposes. I do not know if the internals are smart enough to convert 24V down but it should say somewhere, usually on the charger. If I had my car charger I'd look, but can't. For example, the wall charger that came with our phones can do 100-240V. I would guess you are probably ok, but I wouldn't risk my phone until I knew for sure.
    Check out my themes:
    Rosie685's Avatar
    24697
    91
    So its probably best to buy a charger that says input 12-24v? I bought a replacement awhile ago, just not sure what the input would be.
    Themer
    jeems's Avatar
    40702
    3,747
    73 times
    Quote Originally Posted by Rosie685 View Post
    Yup, assuming they are available. As long is it's certified USB the output should meet the USB standards which should be safe for our phones. I'd buy it from a legit manufacturer as well just to be extra safe.
    Points: 1,323, Level: 20
    Level completed: 23%, Points required for next Level: 77
    Overall activity: 2.1%
    ford7379trucks's Avatar
    15946
    31
    no do not put the phone charger in a 24v outlet. your lucky you didnt fry it. your charger converts 12v to 5v you need a 24v to 5v charger. 5v is usb
    Points: 14,589, Level: 78
    Level completed: 35%, Points required for next Level: 261
    Overall activity: 1.4%
    7 days registeredThree Friends100 Experience PointsYour first GroupCreated Album pictures
    Community Award
    AdamTomaino's Avatar
    434
    Pittsburgh, Pa
    678
    30 times
    Do it!
    Knight AdamTomaino of The X Clan!
  1. Noob trying to under volt. LoL
    By cooksta3276 in forum Droid X Help
    Last Post: 03-05-2012, 06:40 PM
  2. Car cigarette lighter to multiple USB adapter
    By OfficeLinebacker in forum Droid X Accessories
    Last Post: 02-24-2011, 10:46 PM
  3. Anyone using cigarette lighter charger mount? Any reviews?
    By penfan82 in forum Droid X Accessories
    Last Post: 02-05-2011, 12:17 PM
  4. Replies: 3
    Last Post: 12-05-2010, 05:37 PM
  5. Lighter socket mount
    By Lstrk in forum Droid X Accessories
    Last Post: 10-05-2010, 12:10 AM
12 volt car charger hurt iphone 4
24 volt cell phone charger
24 volt outlet
24 volt phone charger
can i charge my iphone with 24v
can u charge motorola phone with 24 volts
can you charge iphone 24 volt
truck cigarette lighter voltage
will a verizon car chargers work on 24 volt
