Charging with a 24 volt cigarette lighter.
This is a discussion on Charging with a 24 volt cigarette lighter. within the Droid X General Discussion forums, part of the Droid X Discussion category; i used to drive tour bus. it was a van hool or something like that i think it was made in norway or something like ...
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Charging with a 24 volt cigarette lighter.
    i used to drive tour bus. it was a van hool or something like that i think it was made in norway or something like that. anyway they had a 24 v that i plugged my portable dvd into and it went pop and started smoking so i took the dvd player back to walmart and got my money back. but it was my fault so yep dont use that 24 v socket
    Did you find a solution? I also run a liebherr! I can charge them in lower cab. But that not useful when I have a 24v right by my head in operators cab!!
    Points: 150, Level: 2
    Rorence's Avatar
    90580
    May 2017
    6
    You tool is for 24v, right? The tool for me is DC 12v to AC 110v, bestek 400w power inverter. I use this tool in the way that connecting with car cigarette lighter charger outlet. From this, we can use bestek 400w power inverter easily and safely. The another advantage of this tool is it much convenient for me to take away when camping outside. I need to charge laptop through using it. If you want to catch more information about it, you can search Bestekmall on Google.
  1. Noob trying to under volt. LoL
    By cooksta3276 in forum Droid X Help
    Last Post: 03-05-2012, 07:40 PM
  2. Car cigarette lighter to multiple USB adapter
    By OfficeLinebacker in forum Droid X Accessories
    Last Post: 02-24-2011, 11:46 PM
  3. Anyone using cigarette lighter charger mount? Any reviews?
    By penfan82 in forum Droid X Accessories
    Last Post: 02-05-2011, 01:17 PM
  4. Replies: 3
    Last Post: 12-05-2010, 06:37 PM
  5. Lighter socket mount
    By Lstrk in forum Droid X Accessories
    Last Post: 10-05-2010, 01:10 AM
24 volt cell phone charger
24 volt cigarette lighter adapter
24 volt cigarette lighter plug
24 volt phone charger
24v phone charger
can a 12v phone charger plug in a 24v out let
can you use 12v charger in 24v cigeratte plug
i plugged my phone into a 24v car charger and it fried my charger
lighters that charge off a cell phone charger
will a 24v outlet fry your phone
