Droid X Sync with iMac
This is a discussion on Droid X Sync with iMac within the Droid X General Discussion forums, part of the Droid X Discussion category; I thought the Droid was supposed to be "open source"? I guess I am not that much of a techi, but if that is the ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Droid X Sync with iMac
    Tagger Second Class
    ckirkpatrick13's Avatar
    555
    5
    I thought the Droid was supposed to be "open source"? I guess I am not that much of a techi, but if that is the case, why do they sync so well with PC's, but not Macs?
    I have an iMac and have downloaded Double Twist, but can't get my damn Droid X to "mount" to my iMac. I keep getting a message that says my computer does not recognize the disk...
    dimachka's Avatar
    145
    use usb mass storage mode, not pc mode, and it should work fine. Mine is working...
    Tagger Second Class
    555
    5
    How do i get it into mass storage mode?
    Tagger Second Class
    555
    5
    I figured out how to put it into mass storage mode. now for some reason it is saying the memory card is missing on the phone. I looked and it is definitely there... Any ideas?
    dimachka's Avatar
    145
    my phone did that the first time i connected it. I just unplugged the usb and plugged in again once the phone knew to use usb mass storage and then it worked. Now ive unplugged and plugged back in several times and it works everytime. Just try a few more times I would say.
    Tagger Second Class
    555
    5
    I feel like slamming my head against a wall. I am trying to switch back to VZW from AT&T, but this is almost not worth it....
    I have disconnected and reconnected countless times and no luck... I have spent 3 hours on the phone with technical support and they don't have an answer because they don't deal with Mac's... This seems ridiculous to me. Isn't Android trying to take back customers lost to the iPhone???? If that's the case, why the heck aren't they compatible with Mac's or iTunes? Bad business model if you ask me...
    dimachka's Avatar
    145
    Android is perfectly compatible with Mac computers. They are not compatible with itunes solely because of Apple's refusal to allow non-apple devices to sync with itunes. The issues you are experiencing are not about android or the droidx in general. Unfortunately i'm not sure how to help you get this issue resolved.
    bkbrown's Avatar
    771
    12
    I'd recommend taking your Mac to the Apple Store and getting them to assist at the Genius Bar. Hopefully they don't give you a hard time about the Droid X, but you DO own a Mac, and Apple said today that they want to make EVERY customer of theirs happy. I would think this would be part of that promise.
    7 days registeredThree Friends100 Experience Points
    shredderx's Avatar
    38
    Temecula
    62
    You need to plug it in and pull down the notification bar on the DX...Use USB Mass Storage
    Points: 1,712, Level: 24
    jhankg's Avatar
    17
    Summerfield, NC
    196
    10 times
    Works fine with my Mac, just are my original Droid does.
Sync droid x with Mac
connect droid x to macbook air
droid x imac
droid x mac sync
how do i connect my droid to my imac
how to make droid compatible with mac
how to sync droid x with a mac
motorola droidx sync to imac
synchronize droidx and imac
syncing droid x to imac
