Tape battery cover of extended battery?
I just ordered an extended battery but it didn't come with a cover. When I put my cover on it and push against the battery I see an indentation on my screen. If I just taped the cover to the phone without locking it down will it be okay?
02-03-2012 05:39 PM
It would be better than nothing, atleast until you get one in
Are you going to use a case? If so don't even worry about the battery door. But otherwise id buy a cheap rubber case and just out it on. But to answer your question tape shouldnt cause a problem.
Ninja'd..
FreeMyMoto!!!
FreeMyMoto!!!
If you need help PM me
Well I had one before from verizon but I hated how my case barely fit on it with the cover. Do I really need a cover with a case?
No you do not need a cover with a case.
FreeMyMoto!!!
FreeMyMoto!!!
Okay I figured. I'll probably just keep it taped incase I take the case off
