Easy battery saver or task killer?
This is a discussion on Easy battery saver or task killer? within the Droid X General Discussion forums, part of the Droid X Discussion category; Should I use these apps? Sent from my DROIDX using Droid X Forums...
Thread: Easy battery saver or task killer?
    Points: 1,993, Level: 26
    Level completed: 93%, Points required for next Level: 7
    Overall activity: 23.7%
    Kench's Avatar
    46594
    Aug 2011
    261
    Points: 1,960, Level: 26
    Level completed: 60%, Points required for next Level: 40
    Scram's Avatar
    36066
    Jersey Shore
    490
    10 times
    Don't know about the battery saver,some are good. Stay away from task killers they are a waste...
    Sent from my liberated DX
    Scram's Avatar
    36066
    Jersey Shore
    490
    10 times
    Stay away from anti virus also...not needed.
    Kench's Avatar
    46594
    Aug 2011
    261
    Okay thanks
  1. Task Killer
    By sundance in forum Gingerbread General Discussion
    Last Post: 06-29-2011, 08:05 AM
  2. Best task killer for GB
    By DroidXWinning in forum Gingerbread General Discussion
    Last Post: 06-09-2011, 12:22 PM
  3. Task killer
    By Chessnut in forum Gingerbread General Discussion
    Last Post: 04-26-2011, 07:18 PM
  4. Best Task Killer?
    By shazbork in forum Droid X Apps
    Last Post: 11-01-2010, 08:14 AM
  5. Advanced Task Killer / conserving battery
    Last Post: 07-22-2010, 06:58 AM
advanced task killer vs. easy
battery saver droid x
droid x battery saver
easy battery saver
easy battery saver app or advanced task killer
easy battery saver or advanced task killer?
easy battery saver task killer
easy battery saver task killer it work
easy task killer
easy task killer & easy battery saver
easy task killer battery saver
easy task killer vs easy battery
easy task or easy battery saver
task killer vs battery saver
www.easytaskkiller
