White vs Blue Signal Bars
This is a discussion on White vs Blue Signal Bars within the Droid X General Discussion forums, part of the Droid X Discussion category; I am on a DB running Gingerbread... It is my understanding that for both WIFI and CMDA 3G Signal bars turn white if my DX ...
Results 1 to 6 of 6
Thread: White vs Blue Signal Bars
    Points: 505, Level: 10
    Level completed: 10%, Points required for next Level: 45
    Overall activity: 0.7%
    sawtooth500's Avatar
    51915
    Nov 2011
    18
    It is my understanding that for both WIFI and CMDA 3G Signal bars turn white if my DX does not have a connection with google servers, otherwise they are blue.
    Assuming that my understanding there is correct, I could understand why on occasion the connection with google servers could be dropped over 3G if I have a very weak connection.
    But sometimes I have a full 3G connection and full WIFI, why in the world would the bars be white then?
    51915
    Nov 2011
    18
    I also have tethering set up on my phone, not the legit kind. I use wifi tether beta. Why is it that every time I enable tethering my bars turn white?
    Also, when the bars are white and with a strong signal, if I cycle the RF on my phone on and off using airplane mode, when the RF reconnects the bars turn blue.
    Points: 2,402, Level: 29
    Level completed: 68%, Points required for next Level: 48
    Overall activity: 21.2%
    Brad92's Avatar
    46310
    Aug 2011
    Bleiblerville, TX
    754
    14 times
    Its how Moto has the Blur ROM setup. Its mainly with tethering that I have seen. CM7 and 2nd init ROMs don't have that issue...
    X
    51915
    Nov 2011
    18
    So is there any practical difference from a usage standpoint if the bars are white or yellow?
    Points: 1,282, Level: 19
    Level completed: 82%, Points required for next Level: 18
    Overall activity: 2.0%
    DroidModderX's Avatar
    50039
    Oct 2011
    135
    No, there isn't.. It's just a common glitch you've already found the problem to by cycling airplane mode.
    It use to bug the heck out of me until I found out what it actually was.
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    DroidModderX...
    Awesome Video's by the way...
    Question...
    What's the differents between Wiping Cache or Formatting Cache? Is their one that works better for performance?...
    Dalvik Cache...What is exactly in Dalvik Cache...Hey, keep the Language close to earth so I can understand...
    Its Bubba
    Quote Originally Posted by DroidModderX View Post
    "Stubborn In You're Bones"
  1. Getting White Wifi Bars?
    By confinedPC in forum Gingerbread Help
    Last Post: 12-27-2012, 10:41 AM
  2. White vs green bars and 3g icons?
    By sierra in forum Droid X Help
    Last Post: 10-19-2011, 06:14 PM
  3. Signal bars to dBm values
    By Blacksantron in forum Droid X Hacks
    Last Post: 08-26-2011, 09:02 AM
  4. Replies: 12
    Last Post: 07-27-2011, 11:38 AM
  5. Signal Bars and Verizon Network Extender
    By ncridgerunner in forum Droid X General Discussion
    Last Post: 08-28-2010, 02:19 PM
android signal bars turn white
android white bars vs blue bars
verizon white bars
verizon white vs blue bars
white signal bars android
white signal bars instead of blue
why are my signal bars white
why are the bars on my droid white
why do my signal bars turn white
why is my 3g signal white
