Droid X and X2 LCD's...can they be interchanged?
This is a discussion on Droid X and X2 LCD's...can they be interchanged? within the Droid X General Discussion forums, part of the Droid X Discussion category; So pretty much as the title states. Can the Droid X and the Droid X2 LCD screens be swapped? (not the digitizer) The reason I'm ...
Thread: Droid X and X2 LCD's...can they be interchanged?
    VDoubleUVR6's Avatar
    1662
    CT
    The reason I'm asking...I have a friend who has an X2 with a broken LCD. They are offering me the X2 phone and said that if its possible to swap my X LCD over then I'll have a newer and hopefully "non self rebooting" phone (yes my X still reboots at random even after two restores and all patches from VZW/Moto).
    And if so I might just search the web and see how much a Droid X replacement LCD costs as I heard the X2 screen lacks quality and looks more pixelated (if that's even a real word).
    Thanks in advance,
    Bruno
    Rescue Squad
    Points: 28,311, Level: 98
    Level completed: 97%, Points required for next Level: 39
    Leach19m's Avatar
    31277
    Washington
    7,053
    234 times
    X2 has a pentile matrix display, while the X does not. So I would assume the power supply and other connections are likely different
    (V) {;,,;} (V) < Woopwoopwoopwoopwoop
    Scuttering along like Zoidberg, on the move
    Points: 49,198, Level: 100
    Overall activity: 3.0%
    macpro88's Avatar
    20491
    6,938
    320 times
    And the digitizer is usually and all in one piece with the LCD screen.
    1662
    CT
    Well I was hoping they were the same though to afraid to open my Droid X to find out as its my only phone. I did though open the Droid X2 last night and the digitizer is fine...the LCD isn't though...
    Quote Originally Posted by VDoubleUVR6 View Post
    I just tried to do this (by accident). The X2 LCD is the same size and has the same connectors, but when installed in an X, the back light wont turn on.
are droid x and droid x2 parts interchangeable
are droid x and droid x2 screens interchangable
can you put a droid x2 lcd in a droid x
do moto droid razr m and moto droid x2 have interchangeable parts
droid x2 digitizer
droid x2 lcd replace with droid x
droid x2 lcd replacement
interchangeable parts for motorola droid x and motorola droid x2?
motherboards compatible with droid x2 lcd and digitizer
will a droidx lcd fit a droid x2
