GOOGLE MAPS NAVIGATION...the turn-by-turn voice commands are GONE!!!
This is a discussion on GOOGLE MAPS NAVIGATION...the turn-by-turn voice commands are GONE!!! within the Droid X General Discussion forums, part of the Droid X Discussion category; before when i used the GOOGLE MAPS NAVIGATION i would get turn-by-turn voice commands. but now out of nowhere they are gone and instead are ...
Results 1 to 10 of 11
Thread: GOOGLE MAPS NAVIGATION...the turn-by-turn voice commands are GONE!!!
    Points: 1,364, Level: 20
    Level completed: 64%, Points required for next Level: 36
    1 year registered3 months registered31 days registered100 Experience Points7 days registered
    fongaroos's Avatar
    3358
    26
    before when i used the GOOGLE MAPS NAVIGATION i would get turn-by-turn voice commands. but now out of nowhere they are gone and instead are replaced with these really annoying bell or chime sounds. it does not read off the street names or the distances or which way to turn.
    any ideas about what happened?!
    Points: 3,573, Level: 37
    Level completed: 49%, Points required for next Level: 77
    Overall activity: 0.6%
    ajp's Avatar
    444
    SD
    223
    Dunno what happened. I'd uninstall, and then reinstall from market. Navigation is included in Google maps btw
    MIUI 1.12.30
    proud X owner since launch day
    Points: 10,255, Level: 67
    Overall activity: 8.4%
    Ampclamp's Avatar
    37298
    Halfway up the Mountain
    447
    27 times
    Need more info to help. Are yo rooted, using a custom rom, themed, are you on .340, .596, .602. Is your X completely stock. Are you using a car dock app? If you are rooted you can try flashing the correct gapps.
    BOOT MANAGER......5 roms 5 times the fun!
    fongaroos's Avatar
    3358
    26
    not rooted, its completely stock. its on gingerbread. no custom roms or themes.
    its system version 4.5.602.MB810
    android version 2.3.3
    baseband version BP_C_01.09.13P
    does that help?
    fongaroos's Avatar
    3358
    26
    and i am not using a car dock. it is just plugged in to a generic aftermarket carcharger to charge the battery.
    Ampclamp's Avatar
    37298
    447
    27 times
    Then I would suggest doing what.....ajp.......said. Uninstall and reinstall google maps from market.
    fongaroos's Avatar
    3358
    26
    hmmm ill try that.
    Points: 691, Level: 13
    Level completed: 82%, Points required for next Level: 9
    Xme's Avatar
    38286
    7
    Just had the same thing happen. Any luck w the reinstall?
    Running MIUI 1.9.16.1.
    Points: 6,119, Level: 50
    Level completed: 85%, Points required for next Level: 31
    Overall activity: 2.7%
    fc127's Avatar
    27223
    Cortland, NY
    1,173
    36 times
    Did you try checking the settings to see if it is muted?
    Sent from MI UI on MY DX.
    Root .602 & .605 info here.
    Need to SBF? Try this.
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    Try going into settings/applications/manage applications/"all" tab... Scroll down to maps and clear data/cache...
    Post Script:
    Nemo Aeternamn Wallpapers
  1. Unmuting Google Maps GPS turn by turn voice navigation
    By Craig225 in forum Droid X Help
    Last Post: 07-04-2011, 07:14 AM
  2. Google GPS. Any app for audible turn by turn?
    By set theorist in forum Droid X Apps
    Last Post: 07-03-2011, 10:20 AM
  3. Not Getting Turn by Turn w/ Google Maps
    By Corpsman in forum Droid X Help
    Last Post: 11-17-2010, 06:30 AM
  4. how to turn off Google Voice for SMS (in Contacts)??
    By bobthebob in forum Droid X Help
    Last Post: 11-03-2010, 08:06 PM
  5. Replies: 0
    Last Post: 10-03-2010, 09:29 AM
droid navigation gone
google gps gone
google maps navigation gone
google maps turn on voice
google navigation app gone
google navigation bell sound
google navigation gone
google navigator gone
no turn by turn voice on droid x
turn by turn view on navigation android view gone
