Turn by turn trip
This is a discussion on Turn by turn trip within the Droid X General Discussion forums, part of the Droid X Discussion category; Hey I was wondering if there was a trip app that used the gps so I could do a multi point trip with turn by ...
Thread: Turn by turn trip
    Question Turn by turn trip
    Hey I was wondering if there was a trip app that used the gps so I could do a multi point trip with turn by turn directions to each point. So all I would do is enter the adress and have the the app route tripe.
    Thanks
    Adam
    thethickness's Avatar
    3438
    NC
    58
    Pretty sure the preloaded Navigation app can do that for you.
    I used it the other day to get re-routed around a big traffic jam on I-40 coming back from the airport. Punched in my destination and it got me there just fine. If I had a car mount it would have been a garmin replacement for sure.
    BB 8700-> BB Curve-> BB Tour-> DROID X!
    Y.I.T.B.O.S.
    Yea but can it do multipoint turn by turn that way I can just load astart point an end point then a bunch of points in the middle and have it direct me to the end point but still hit all the points in between. I am taking a road trip and I know where I want to end up but I have a few stops along the way.
    Tagger Second Class500 Experience Points250 Experience Points100 Experience Points7 days registered
    baniels's Avatar
    30
    52556
    369
    26 times
    I don't know that it can do that. Your best option would be to go into maps on your phone and save each of those locations. Then you can easily route to the next waypoint when you are back on the road.
    Click on the star in the upper right corner when viewing the details of any location. For instance, if you click on a search result, a speech bubble with a little info will come up. Click on that bubble, then you will be on the detail view for that location. That is where you will find the star.
    All of your starred locations will show on your main map view so you can pull them up with a couple clicks.
    Happy Birthday Spray, I'm Disappointed in You.
  1. Google GPS. Any app for audible turn by turn?
    By set theorist in forum Droid X Apps
    Last Post: 07-03-2011, 10:20 AM
  2. Bluetooth will not turn on
    By Trabecca in forum Droid X Help
    Last Post: 01-20-2011, 09:18 PM
  3. Can't turn off WIFI!
    By Lumberg in forum Droid X General Discussion
    Last Post: 09-23-2010, 08:30 PM
  4. Turn off T9?
    By KiX in forum Droid X General Discussion
    Last Post: 08-11-2010, 12:41 PM
  5. Way to turn off
    By Bill in forum Droid X General Discussion
    Last Post: 07-29-2010, 08:22 PM
android multi point gps routing
android multipoint navigation
custom route with turn by turn directions android
droid x custom route navigation
droid x turn by turn directions for custom route
how to turn on turn by turn on droid x
multi poi route android
multipoint navigation android
turn off predictive text galaxy s3
turn off predictive text on droid x
