WiFi only mode?
This is a discussion on WiFi only mode? within the Droid X General Discussion forums, part of the Droid X Discussion category; I'm going on a vacation to the Bahamas and was wondering if there was a way to disable to phone / 3g services on the ...
Like Tree3Likes
  • 1 Post By FMMFL
  • 1 Post By validoption
  • 1 Post By CrashF16
Thread: WiFi only mode?
    Points: 1,218, Level: 19
    Level completed: 18%, Points required for next Level: 82
    bchampnd's Avatar
    1354
    6
    WiFi only mode?
    I'm going on a vacation to the Bahamas and was wondering if there was a way to disable to phone / 3g services on the X and have it use WiFi only. I want to be able to use my X as a camera, check email and do some web surfing but want to avoid a racking up a crazy bill due to international calls, data charges and text messaging charges.
    I was wondering if putting the phone on airplane mode and then enabling WiFi would do the trick. It seems to work but I wanted to know if anybody else had any experience with using this method or some other way of preventing the phone from creating a big bill.
    validoption's Avatar
    1423
    232
    17 times
    Quote Originally Posted by bchampnd View Post
    That would have been my suggestion.
    Sent from my DROIDX
    bchampnd likes this.
    31 days registered250 Experience Points100 Experience PointsTagger Second Class7 days registered
    CrashF16's Avatar
    815
    202
    18 times
    By turning off data roaming, you should be good to go. I've been using mine out of the country for a couple weeks with Data Roaming off and am in Airplane mode with wifi turned on. Works like a champ.
  1. Safe Mode
    By theNet in forum Droid X Hacks
    Last Post: 12-14-2010, 01:45 PM
  2. Help with Vibrate mode
    By winger53215 in forum Droid X General Discussion
    Last Post: 08-06-2010, 08:51 AM
  3. Self Portrait Mode
    By TrueGreenSpartan in forum Droid X General Discussion
    Last Post: 07-19-2010, 12:51 PM
  4. Landscape mode only works if
    By silent1643 in forum Droid X Help
    Last Post: 07-19-2010, 10:33 AM
  5. PC Mode
    By DavedroidX in forum Droid X General Discussion
    Last Post: 07-16-2010, 10:44 AM
android wifi only mode
can i use my droid x in wifi mode only?
droid x airplane mode wifi
droid x setting to use only wifi
droid x wifi only
droid x wifi only mode
how do i only do wifi on a droid x
how to set your droid x to wifi only
how to use driod in bahamas wifi
make a wifi only droid x
