Bluetooth, how much battery does it use??
This is a discussion on Bluetooth, how much battery does it use?? within the Droid X General Discussion forums, part of the Droid X Discussion category; I use headphones all day at work listening to online Sirius Radio. In the morning, I need to use wired earbuds as I listen to ...
Results 1 to 7 of 7
Thread: Bluetooth, how much battery does it use??
    Points: 1,817, Level: 25
    Overall activity: 1.5%
    jmorton10's Avatar
    9150
    310
    I use headphones all day at work listening to online Sirius Radio. In the morning, I need to use wired earbuds as I listen to a station on the FM radio app & that only works with wired headsets.
    The rest of the day however, I can use either my Ultimate Ears earbuds or my Motorola S9 HD stereo BT headset. Does anybody know how much extra battery life I would get by using the wired set all day as opposed to swapping out to the BT set??
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Not sure exactly how much bluetooth drains your battery, but I use BT and non-BT frequently and I don't notice much of a difference. Obviously it drains more, but I think the data connection constantly running from streaming music is much more of a battery drain IMO.
    Personally, I love my BT headphones over wired enough to ignore any extra battery drain. I figure I can leave my phone on the charger if need be and then I don't have to be right next to the phone as I would if I were wired.
    Also, TuneIn Radio likely has the station you listen to if you want to use BT. TuneIn will drain more than the FM radio due to the data connection, but as I mentioned, you could leave it charging while its playing and still have the wireless freedom of bluetooth.
    jmorton10's Avatar
    9150
    310
    unfortunately, the station I listen to is blocked from tune-in. It works on iheart radio, but iheart rebuffers so much it is virtually useless.
    ~John
    Points: 48,761, Level: 100
    Overall activity: 17.2%
    gbrinn's Avatar
    38696
    Headed to Duke University Hospital
    17,707
    727 times
    For me, just a 20 minute run using my Motorola S10-HD headphones and Doubletwist will drain about 10% according to the battery meter. But, since the darn meters only work on the 10th percentile on the Droid X, who knows how accurate that is...
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    I also stream online radio with abd without bluetooth and I've never noticed a difference in battery drain. I also never have seen Bluetooth show up on the battery usage screen.
    Liberty 3 -- too many roms too little time.
    gbrinn's Avatar
    38696
    17,707
    727 times
    The 10% or so drain by using BT headphones isn't worth NOT using them. They are fantastic when running or when I'm in the car (doubles as hands free).
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
    Points: 7,762, Level: 59
    Overall activity: 1.2%
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Quote Originally Posted by C Dippa View Post
    Thanks tune in radio works like a champ!! Never knew about this app I use my local radio app but it doesn't work on cm7.
    Sent from Mopar-x
  1. Bluetooth Share draining my battery
    By just lou in forum Droid X Help
    Last Post: 02-17-2011, 02:52 AM
  2. Bluetooth issues (recently acting up with vehicle bluetooth interface)
    By buzzdroidblitzz in forum Droid X General Discussion
    Last Post: 12-13-2010, 06:52 PM
  3. Replies: 0
    Last Post: 09-19-2010, 08:47 PM
  4. Slick little app for for preserving battery life when using Bluetooth
    By AndroidScott in forum Droid X General Discussion
    Last Post: 09-08-2010, 12:31 PM
  5. Replies: 7
    Last Post: 09-06-2010, 01:49 PM
does bluetooth consume a lot of battery
does bluetooth use a lot of battery
does bluetooth use a lot of battery power
does bluetooth use more battery
does bluetooth use much battery
does using bluetooth use more battery
how much battery does bluetooth use
how much battery does bluetooth use android
how much does bluetooth drain battery
how much power does bluetooth use
