Possible to customize keyboard layouts without modifying keyboard?
This is a discussion on Possible to customize keyboard layouts without modifying keyboard? within the Droid X General Discussion forums, part of the Droid X Discussion category; Finally, in GB my phone has the ability to swipe on the space bar and change to Russian. Only, I'd like to customize that Russian ...
Thread: Possible to customize keyboard layouts without modifying keyboard?
    Points: 2,612, Level: 31
    Level completed: 8%, Points required for next Level: 138
    armedmonkey's Avatar
    4289
    293
    Finally, in GB my phone has the ability to swipe on the space bar and change to Russian. Only, I'd like to customize that Russian layout to one of my own (Phonetically arranged so that the Russian keys match up best to the English keys because I'm not used to the standard Russian one).
    Is this possible? I've seen other posts around the web where it was suggested to download a custom keyboard, but I don't want to do that. I'm willing to do the hacking myself if someone points me in the right direction of where these layouts are stored.
    Thanks DXForums!
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    you would essentially have to build the keyboard from scratch if you wanted to re arrange the keys. It wouldn't just be xml edits you would have to rework some of the java code that underlies it.
    but if you want to try here you can go to start reading up
    http://developer.android.com/reference/android/inputmethodservice/package-summary.html
    t
    hat is just the summary and you can go through each one on the left of the screen to find classes and the xml attribute associated with it
    more info:
    http://stackoverflow.com/questions/3480715/how-to-develop-a-soft-keyboard-for-android
    http://android-developers.blogspot.c...on-screen.html
    4289
    293
    really? all of those languages are hardcoded in the apk?
    cory46's Avatar
    8051
    4,768
    125 times
    yeah but if you want to switch the layout from what is already coded in you'll have to rework the code. Its already coded in a certain way for the keys to show up in certain spots and if I am understanding you correctly you want to rearrange the keys right? those articles should point you to the correct spots.. or you can decompile the apk yourself look through all the xmls and see if each one has a specific spot for each key or key press
    edit: you may be able to edit this xml in the picture below not going to guarantee it will work but it does have layout in it
  1. Replies: 1
    Last Post: 06-13-2011, 08:22 PM
  2. Customize google search widget and swype keyboard
    By Musicman in forum Droid X Hacks
    Last Post: 02-12-2011, 11:33 PM
  3. Another Keyboard - Thumb Keyboard...
    By smalltowngirl13 in forum Droid X Apps
    Last Post: 01-19-2011, 02:44 PM
  4. Replies: 9
    Last Post: 11-10-2010, 11:16 PM
  5. No Root CUSTOMIZE SWIPE KEYBOARD
    By lterry913 in forum Droid X General Discussion
    Last Post: 09-29-2010, 06:06 PM
android custom keyboard
android custom keyboard layout
android custom keyboard view
android custom keyboardview
android keyboard custom layout
arrange android keyboard
custom android keyboard layout
custom keyboard layout android
customize android keyboard layout
rearrange android keyboard
