Dalvik cache: what is it and when do I need to clear it?
This is a discussion on Dalvik cache: what is it and when do I need to clear it? within the Droid X General Discussion forums, part of the Droid X Discussion category; Thanks. I follow instructions when flashing roms and some say to clear dalvik cache. What is it and is it necessary? Also, if i occasionally ...
Results 1 to 10 of 17
Thread: Dalvik cache: what is it and when do I need to clear it?
    Points: 3,488, Level: 36
    Level completed: 92%, Points required for next Level: 12
    kochoid's Avatar
    36580
    247
    Smile Dalvik cache: what is it and when do I need to clear it?
    Thanks. I follow instructions when flashing roms and some say to clear dalvik cache. What is it and is it necessary? Also, if i occasionally go in to clockwork recovery and clear it, does it help/hurt anything?
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    it can be the cure to a some problems.. it really wont hurt anything to do it but if the instructions say clear it go ahead and clear the developer said to do so for a reason
    Dalvik is the process virtual machine (VM) in Google's Android operating system. Dalvik is thus an integral part of Android, which is typically used on mobile devices such as mobile phones, tablet computers and netbooks. Before execution, Android applications are converted into the compactDalvik Executable (.dex) format, which is designed to be suitable for systems that are constrained in terms of memory and processor speed.
    Dalvik, like the rest of Android, is open-source software. It was originally written by Dan Bornstein, who named it after the fishing village of Dalvk inEyjafjrur, Iceland, where some of his ancestors lived.
    Dalvik (software) - Wikipedia, the free encyclopedia
    I
    should add that sometimes I cleared mine through titanium and it seemed to speed to phone up if there were a lot of junk there.. then again it might have been a placebo effect...
    ToeJamm57 likes this.
    Points: 553, Level: 11
    Level completed: 6%, Points required for next Level: 47
    Recommendation Second Class250 Experience Points31 days registered100 Experience Points7 days registered
    Droidgasm's Avatar
    38513
    30
    I'd been wondering about this as well but never bothered to do the research. Thanks for the explanation!
    Points: 1,573, Level: 22
    Level completed: 73%, Points required for next Level: 27
    Freethinker's Avatar
    41087
    7
    In that same vein...
    I always do a backup in CW before making changes to my phone. If something does go wrong, stuck in boot loop etc, I just restore and all is back to working. There's probably a fix to a problem such as wiping or clearing cache, factory reset etc but I'm unsure what each does and when to use a certain fix as opposed to simply restoring. Any thoughts?
    Points: 49,198, Level: 100
    Overall activity: 3.0%
    macpro88's Avatar
    20491
    6,938
    320 times
    Quote Originally Posted by Freethinker View Post
    Always start with cache and dalvik cache first, it that don't solve the issue, then doing a factory reset might. If that don't solve it either, then restoring a backup/SBF should fix it. If I have any major issues, I almost always SBF back first to the base of my nandroid, then restore that nandroid on a fresh base.
    cory46's Avatar
    8051
    4,768
    125 times
    Well the easiest way I can explain it because a: I know enough to get myself in trouble b: I don't know enough haha to please my own curiosities.
    When installing a new ROM say you were stock rooted gingerbread build and wanted to get a ROM you should backup the working stuck version then wipe data and cache to make sure you have a nice clean environment. Dalvik wouldn't hurt either.
    In the bootloop case sometimes that is caused by remnants of data left over so a data wipe could bring you out of that bootloop .
    Data will always wipe all internal memory ( apps and such)
    Cache is like cleaning out your work desk you have papers files and folders stored there for easy access and after a while sometimes they aren't needed so you pitch them haha
    Edit: o and listen to mac's advice haha
    I haz interwebz
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Dalvik restructures the framework on boot after you wipe which is why a dalvik wipe will result in a longer boot time (as it recompiles the framework). When switching from theme to theme, its good to wipe dalvik to avoid theme overlap
    X Pursuant Achievements:
    dennyjones's Avatar
    14832
    649
    13 times
    Very informative thread. Thanks.
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    If your flashing Themes from one ADW Theme to another, do you still have to wipe cache in Dalvik?
    Or is it from ADW Theme to Launcher Pro to wipe Dalvik
    Its Bubba
    "Stubborn In You're Bones"
    cory46's Avatar
    8051
    4,768
    125 times
    Quote Originally Posted by The persuader View Post
    Its Bubba
    I've never wiped with ADW or launcher Pro themes sooooooooooooooI dunno if that would help or not
  1. Why is there so much cache and how do I get rid of it all?
    By Xponentially Better in forum Gingerbread Development and Hacking
    Last Post: 06-02-2011, 10:56 AM
  2. Bootloop after Dalvik VM and Max Events change!
    By coldcaption in forum Droid X Rooted Issues
    Last Post: 05-30-2011, 10:15 AM
  3. pictures not showing up after wiping dalvik cache
    By amm5890 in forum Gingerbread Help
    Last Post: 04-30-2011, 05:27 PM
  4. Clear notifications?
    By spmdroidx in forum Hacking Help
    Last Post: 02-17-2011, 01:00 AM
  5. How do I clear my "system cache?"
    By AndroidScott in forum Droid X Help
    Last Post: 09-25-2010, 12:03 AM
clear dalvik cache
is it ok to clear dalvik cache
is it safe to clear dalvik cache
what does clearing dalvik cache do
what does dalvik cache wipe do
what does wipe dalvik cache do
what is dalvic cache
what is dalvik cache
why clear dalvik cache
wipe dalvik cache
